Question about Garden
I have a Franks Broadcast spreader as well. Is there a calibration chart for this spreader.
  • 2712 Answers
SOURCE: Drop and Broadcast Spreaders comparison
There are two common types of lawn spreader: drop or broadcast. The drop spreader is a familiar sight at garden centers and hardware stores. If you are a homeowner with less than 5,000 sq.ft. of lawn area, an inexpensive drop spreader may be all you need. Drop spreaders tend to be more manueverable in tight, awkward spaces and are relatively easy to use. Broadcast spreaders throw the material out in a wider swath, sometimes as wide as 8'. If you have a large area to cover, they can make short work of it. They are, however, a little trickier to use, since you need to keep up a steady walking speed (usually 3 mph) and you need to be moving when you activate the spreader. It's also harder to get a clean edge, although some broadcast spreaders come with side deflectors, which let you get close to side-walks, beds and driveways without spreading material on these adjacent areas. There are also small, hand-held broadcast spreaders suitable for smaller areas.
Posted on Aug 27, 2008
SOURCE: Spreaders Guidelines
guidelines for setting spreader
Posted on Oct 30, 2008
SOURCE: Need a quick way to convert Scott's settings to Earthway setting
add 10 - scotts turfbuilder spread at 4 on a scotts spreader should be on setting # 14 on an earthway spreader. happy yardening !
Posted on Jun 11, 2009
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
  • 8 Answers
SOURCE: I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Posted on May 06, 2010
What setting do I set my Scotts speddy green 2000 broadcast spredder to spread colonial bentgrass at 2 lbs per 1000 sq ft?
Scotts Spreaders
Robert, Normally the bag tells you the setting to use, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Scotts Spreader Settings Helper Tools Scotts
How to Calibrate Scotts Speedygreen 2000 Lawn Spreader eHow
Lawn Care Basics How To Use Lawn Spreader by Scotts
Mar 23, 2016 | Scotts Garden
Settings for the true tmper sb2000 broadcast spreader
forums.gardenweb.com/forums/load/lawns/msg0313480530229.html
www.amestruetemper.com
May 10, 2014 | Garden
How do you check to see if calibration is exact
Usually the cheaper residential grade spreaders are not exact, nor do they need to be. The best way to tell how close it is, is to measure the area to be fertilized length and width. Multiply the two numbers (example: 30' x 40' = 1,200sq ft.) Adjust the spreader according to the reccomendations on the bag, and follow the directions exactly! Walk at a brisk pace around the perimeter once, and then back and forth spaceing your passes about 5' for rotory spreaders. Compare the amount of product you used, to the coverage chart on the bag. In my experience, most all lawn fertilizers are best spread at 50% to 60% open on your spreader setting adjuster. (example: If your spreader has settings of 1-15, I'd go with 8) Always follow the directions on the product container as best you can. Spreading a little too heavy, or a little too light is not going to hurt anything, so there is no reason to be concerned with exact calibration unless you are applying discriminative herbicides... Hope this helps!
Oct 08, 2011 | Scotts Company 589384 Scotts 5000 SQFT...
I purchased my "Pro" edgeguard
The Scotts Pro Edgeguard Spreader is calibrated at the factory. This spreader cannot be calibrated, and shouldn't need to be. For further assistance, call Scotts at 877-465-5160
Hilary @ Scotts
Aug 16, 2011 | Scotts Company Scotts Pro Edgeguard...
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
How do i calibrate my speedygreen 2000 broadcast spreader
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you need further assistance feel free to contact us @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Scotts& Accugreeen 2000...
Conversion Tables---- I have an Earthway broadcast spreader--need to know if there is a chart that converts Scott's settings located on the back of all Scott's fertilizer bags to Earth way settings?
Mar 16, 2010 | Earthway Ev - N - Spred Model 2050p Estate...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
To adjust calibration, do the following:
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
