Get hot water for about 2mins then goes cold no matter what you do to the tempeture after itstays cold until you turn it off
  • 3 Answers
Then you should do is dont turn.kokolakwek-kwekkaka
Posted on Sep 06, 2010
Miele front load washer on hot setting does not step on when at main wash after 20min and clothes not hot.works fine on cold wash
are u getting hot water from the water inlet valve or house water outlet? if so u may need to check the water tempeture control knob with a multimeter
Mar 02, 2015 | Miele Washing Machines
Water is cold regardless of the setting
I would check the water tempeture knob with a multimeter, u did check the water outlet hoses to see u are getting hot and cold water from them? Also if ur water inlet valve is bad it may only allow cold water or only hot water?
Feb 26, 2015 | Washing Machines
I change thermostat, water pump, housing coolant sensor, but yet when i start driving the tempeture goes up and down and the heat gets kind of cool not all
poor coolant flow water pump? air lock in system? bring to operating temp shut down than open air bleed screws.
Jan 02, 2014 | 1997 Pontiac Sunfire
Setting is on cold/cold, but only burning hot water is coming out. When I switched it to warm/cold, it got a little cooler but still not cold. The hot/cold setting is also just warm water, so the hottest...
This seems to me to be that the hoses are connected backwards. It matters very much which hose is connected to which inlet. Make sure that the hoses are on Hot to "H" and Cold to "C" on the machine.
Aug 29, 2011 | Admiral AW22 Top Load Washer
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
I have a Rheemglas Fury Model #81V52S C, MFG date 05/2003, 50 gal Does not heat properly--not long enough. I Cannot find a gauge, or know how to adjust tempeture--hope that is only problem--please...
One of the elements may be bad. With the power off check each one with an ohm meter. Should show continuity.
The tube the cold water come in through goes to the bottom of the tank. If it has come loose and the cold water stays on the top you wouldn't have much hot water.
Jan 01, 2011 | Rheem Water Heaters
Water tempeture gets hot then cool
Have you tried turning off the valves to the water heater and making sure you have no water flow out of the hot water tap? When this happens, often it is because of a problem with a shower cartridge allowing the cold water to cross over into the hot water side. It makes the unit think that the flow has reduced and the heater will turn down or shut off. Then things bounce back and forth Hot to Cold then back to Hot.
Mar 28, 2010 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
WHEN YOU TURN TEMPETURE GAGE TO COLD MACHINE WON'T WORK. IF YOU TURN TO WARM, ONLY HOT COMES OUT. WHAT CAN I DO?
make sure your hot and cold water is on fully, make sure your hot and cold water is going to right solenoid on washer.
Sep 23, 2009 | GE WDSR2080D Top Load Washer
Hooking up the cold and hot water in back of the washing machine
In a word Yes!!
The machine will fill with Hot water to rinse and if that water is as hot as the normal supply your clothes will shrink and the colours will run.
You need the hoses and the supply to the hoses to be correct so that when you put it on a cool wash it fills with cold water and brings the temperature up to the right level.
Bringing in hot water will kill the soap powders action.
Also the machine adds hot and cold water to make sure that it gets a correct balance for other programs
If you are not sure how they are connected then look at the back of the machine, there should be either a H and C stamped into the backplate or the inlets are Red and (White or Blue).
If the hoses coming from the fawcets are the same colour then take one off the machine place the end in a bucket and turn the fawcet on , if it does not get hot then its the cold one so then make sure it goes back onto the C or the White connector
Jun 22, 2009 | Hotpoint Washing Machines
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
