We just moved into a home that has a honeywell ac/heat system. There is no manuel to set the control timers and temperature and we are starting to get some chilly mornings here in Minnesota. Could you please send me a manuel for the T8001C model. There is also a 9825 E number inside the cover. I am about to buy a new thermostat just to get the instructions but that doesn't seem to smart on a fixed income. Wait your reply. Rita McCauley mccauley567@msn.com
TJBENGR
  • 121 Answers
SOURCE: how to change the battery
The battery is inside the thermostat. There should be screws / or / it will just pry off the mounting base (not the wall). There are usually rechargable batteries inside.
Posted on Apr 28, 2008
  • 18 Answers
SOURCE: Inside blower not starting every time
This should have a time delay sequencer for the blower in the a/c mode. These are bad about being interminent in the a/c mode and also in fan. I have had some that would freeze up and I would get there and the fan be running. Thaw out and check and everything be ok. Got to cycling the fan on and off and sooner or later it would get where fan didn't come on. After replacement the customer didn't have anymore problem. Check the rely, looks like a heat sequencer but mounted on plate to blower compartment.
Posted on May 15, 2008
pal03246
  • 726 Answers
SOURCE: 2002 nissan pathfinder LE heat/AC fan stays on highest speed all of the time
Could be one of 2 things. It could be blower motor resistor or blower motor amplifier. If you have AUTO AC feature/setup, than it will be the amlifier. If you have manual AC than I would look at the resistor, but sounds like you have AUTOAC system, so get the amlifier checked. Its behind the glove box screwed to the air box assembly. 2 screws and its out. Hope this helps. Good luck and let me know what you found.
Posted on Oct 26, 2008
  • 27 Answers
SOURCE: Honeywell PRO TH4110d Prog Thermostat not responding
cfheck to make sur ethat the t-stat is set for your type of heat. if you do not go through the instructions sep by sep then you will have problems. if you have then call a professional.
Posted on Nov 26, 2008
frcs68
  • 1605 Answers
SOURCE: I need user's manual for Danfoss Randall Thermostat TP4000
go to the following link.
download and print the user namual.
http://randall.danfoss.com/PCMPDF/40811v01.pdf
Posted on Apr 06, 2009
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
My timer is set to shut off at a certain time of day, and I want to turn the timer off, but I can't figure out how to do it. Can you send instructions on how to turn the timer off?
Honeywell product is not identified.
More information is needed to identify product. Add a comment with as much information as possible, to help expert locate correct information.
For example Honeywell makes timer controls for boiler and heat-ac units.
Honeywell also makes Aube brand wall and box timers for lights and pumps.
http://waterheatertimer.org/Aube-timers.html
Honeywell has a contact-us page:
https://honeywell.com/Pages/contact-us.aspx
Aug 30, 2011 | Honeywell 24-hour Timer Control 120v Spdt...
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
Cannot set timer on central heating/water system.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jul 27, 2010 | Honeywell Heating & Cooling
Honeywell smartfit controller not adjustable
Go to honeywell.com
Mar 10, 2010 | Honeywell Heating & Cooling
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
