Where on the dimension 4 is the connection to connect to a pre amp I want to connect to a pre amp with phono connections, what cable connections would i need at the power amp end.
  • niron_ramdan Sep 07, 2010
    There is a 6.35mm female jack input A
    Genius:
  • 1,175 Answers
If this amp has an AUX input , use that to plug the phono pre-amp into
and clarify what you mean by "power amp end"
Thanks
Posted on Sep 07, 2010
  • Scott Frye
    Scott Frye Sep 07, 2010
    Is this a Numark Dimension 4 ?
    If it is , it's a power amp and you'll need a mixer or pre-amp to use it
Do you need a pre-amp to connect this turntable to a receiver that has no Phono input jack?
Yes, a TurnTable can be connected to any of the Analog Audio Input ports on the Sony STRDH130 Receiver. However, the turntable signal will need amplification from an external pre-amplifier (or an inline amplifier) as this Receiver does not have a PHONO input.
Feb 16, 2018 | Sony Audio Players & Recorders
How to connect dav-hdx 900 to turntable
Firstly, your turntable will need a phono pre-amp. This can either be built in or an external box.
Connect the pre-amp phono out to the DAVHDX900 Sat.Cable 'R audio in L' sockets.
Aug 23, 2014 | Audio Players & Recorders
Hooking up phonograph to Pioneer VSX-D498
You'll need a phono pre amp and then you can connect to aux inputs.
http://www.google.com/search?q=phono+pre+amp&rlz=1C1CHMO_enUS514US515&aq=f&oq=phono+pre+amp&sourceid=chrome&ie=UTF-8#q=phono+pre+amp&hl=en&tbo=u&rlz=1C1CHMO_enUS514US515&source=univ&tbm=shop&sa=X&ei=Kv_2UMatJoOc9QSDr4CoAg&ved=0CGQQsxg&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.eWU&fp=a656d84bcd78ba72&biw=1360&bih=643
Jan 16, 2013 | Pioneer VSX-D498 Receiver
Distorted sounds
The AT-PL120 uses a magnetic cartridge to extract a music signal from the record. Magnetic cartridges all put out a very weak electric signal, and so their output must be strengthened, or amplified, to where it is as strong as the input from, say, a CD player. This amplification is provided by a pre-amp. If your receiver has dedicated "phono" inputs the pre-amp circuits are already in the receiver. If you do not have dedicated phono inputs you must either buy a pre-amp, or buy a magnetic cartridge turntable with a pre-amp built into itself. The AT-PL120 has a built in pre-amp. You can switch the AT-PL120's preamp on or off. The switch is located under the platter at the back side of the turntable. Take the platter mat off and turn one of the platter's holes to the back and you should see the switch through the hole. If you push the switch to LINE OUT the preamp is turned on and the turntable sends an amplified cartridge signal out the cables which MUST be connected to a receiver inout suitable for a CD player (a "high level" input). If you push the pre-amp selector switch to PHONO OUT the turntable sends the weak unstrengthened cartridge signal out the cables which MUST be connected to the receiver's dedicated PHONO inputs so the signal can be amplified with the receiver's own pre-amp circuits.
If everything is set wrong (i.e. LINE OUT (pre-amp on), and connected to phono inputs) you are applying two steps of strengthening to the turntable's signal which is too much. The resultant sound will be garbled. Try not to do this!
The other way to do everything wrong is set the pre-amp switch to PHONO OUT (pre-amp off) and connect the turntable's cables to a high level input. If this happens the turntable signal receives no amplification and the resultant sound will be thin and weak.
May 09, 2009 | Audio Technica AT-PL120 Turntable
I have recently purchased a arcam alpha 10 amp to go with my arcam alpha 9 cd player and my monitor audio rs8 speakers. I am pleased with the amp and i am thinking of adding the power amp, the problem is i...
A better solution is like I have mine; use the Arcam 10 connected to the tweeters of your speakers & the power Amp connected to the woofers & link the pre out's on the 10 to the power Amp. using phono cables. The Manual can be downloaded from Arcams discontinued section of their website.
This Bi-Amp method gives a far superior sound than just using the 10 as a pre Amp.
May 04, 2009 | Audio Players & Recorders
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
No music
Where do you have the turntable connected? Is it going into a DJ Mixer, a Receiver, or a Power Amp?
No matter the unit, make sure you have it plugged into the PHONO INPUT connection on the rear. If your receiver/amp does not have this, then you will need a PHONO PRE-AMP - The turntable connects to the PHONO PRE-AMP, and the PRE-AMP connects to the LINE IN or AUX IN of your receiver.
If you are connected to the PHONO INPUT of your mixer/receiver/amp, then the problem might be one of the following on the turntable:
1) Tonearm
2) RCA Cables
3) Cartridge
There is no easy way to see which one of these is the culprit, it's just a matter of elimination.
But, you didn't provide much information. If you can be more specific as to how you have your turntable connected, what kind of cartridge your using, and whether or not, you've determined that the problem is indeed the turntable and not your mixer/receiver/amp, or even your speakers. This would help in determining what the issue might be.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.DJPROLAB.com
Jul 16, 2008 | Audio Players & Recorders
SONY TURNTABLE PSLX22
You have to make sure your unit is connected to the PHONO INPUT connection on your receiver. If your receiver does not have a PHONO INPUT connection, then you will need to buy what's called a PHONO PRE-AMP - AVAILABLE HERE.
You connect the turntable to the Phono Pre-Amp, then you connect the Pre-Amp to the LINE IN or AUX IN of your receiver.
- Davis.
DIGITAL ANALOG THERAPY
www.repairnyc.com
Jul 05, 2008 | Sony PS-LX250H Turntable
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
Background huming
How does it sound when you just play straight vinyl through your system? If you still get that hum, issue might also be faulty RCA cables, and even cartridge. So you would need to test everything out.
You don't really need a pre-amp unless you are connecting straight into your pc from your turntable. In that case, yes you will need a pre-amp, and this actually might be the cause of everything. If you are going into a DJ Mixer or a receiver, and your turntable is connected to the PHONO INPUT connection, you do not need a phono pre-amp.
Here are some inexpensive PHONO PRE-AMPS.
Hope this helps some.
- TWEAK AV LAB
Nov 25, 2007 | Audio Technica AT-PL50 Turntable
57 people viewed this question
 Grubhead
Grubhead
