Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Can install this product inside my garage (on top of sheet rock)?
  • 565 Answers
Sorry, no, all landscape low voltage transfomers must be installed outdoors per UL1838.
http://www.ul.com/global/eng/pages/offerings/industries/lighting/lightingindustryservices/standards/ul1838/
Posted on Sep 08, 2010
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
Jan 18, 2014 | Plumbing
Tip
Sheet rock on nine foot walls made easier
if you find yourself hanging nine foot walls with fiftyfour inch rock and the walls are
wooden framing, most have two boards running horizontal along the top. tap five
or six drywall nails along the top of the sheet were they will catch that top plate
and forget the screw gun save your back . use both hands get the sheet in place,
stay in tight with the sheet draw your hammer from your belt and tap in the prestarted nails.Three nails is enough to hold it if they are driven properly. But get
some screws in it asap. seems to save on my back hope it helps yours. Also works
well with two people as well.
on May 17, 2015 | PrimeSource Gypsum Board To Wood Stud...
Dont know how to remove the bedding from the bassinet to wash
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Jun 07, 2011 | Eddie Bauer Musical Rocking Bassinet...
Install question for clearances to combustiable material
Rock ... as in stone? ... or rock as in sheet rock? Your new grill no doubt came with a installation guide and there should be guidance in that guide about clearances. If your grill was not intended to be built in - it will say that in that guide.
I am not familiar with this particular model, generally speaking, I would say if this is outside and you have 4 inches between the grill and rock (rock as in stone), your stone shuld not be in danger though it may get warm.
Thanks for your interest in FixYa.com
May 31, 2010 | DCS BGB36BQARN (NG) Stainless All-in-One...
My Rinnai is too noisy, attached to sheet rock garage wall but other side is a bedroom. Grandaughter is afraid to sleep in that bedroom. Rinnai rep says the noise is normal....
is this a rinnai water heater if so the noise likely is normal it is from the enormous amount of fuel that is being burned to heat water quick enough to get hot water to your faucet.
Sep 12, 2009 | Rinnai Toyostove Direct Vent Heater:...
Installation of our whirlpool tub
Your sheet rock will go to the top of the lip of the tub and then your tile will overlap this lip. If it isn't done right, your grout will crack if you are tiling.
Mar 22, 2009 | Home
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
145 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
