Question about Canon PC-920 Black and White Copier
It says it needs paper and stops even though the paper is full
    Problem Solver:
  • 6 Answers
It sounds like the paper sensor actuating arm is hung up or has broken off.
Posted on Sep 11, 2010
Printer wont pick up paper even though the paper tray is full
There probably is a small piece of paper stuck in the paper path. Please take the ink/toner out of the machine and check the paper path. Please turn off the machine before doing this.
Jul 09, 2015 | Office Equipment & Supplies
The "add paper light" is on even though the paper
The light means that the printer is out of media, or the media did not feed properly
What you can do
-Load media into tray and press Continue button to resume printing.
-Check that the media is loaded correctly in tray
-Press Cancel button to cancel the print job.
Jun 29, 2011 | Lexmark E232 Laser Printer
Showing out of paper even though paoer loaded
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 10, 2009 | HP DeskJet 3940 InkJet Photo Printer
Brother HC4040CN displays error message NO PAPER even though paper tray is full. Will not feed paper from Main tray.
The paper sensor flag above the paper tray on the printer chassis is either stuck or has broken of. You need to take the printer for repairs.
Aug 04, 2009 | Office Equipment & Supplies
The printer says it is out of paper, even though it is loaded
clean your paper rollers in side printer and make sure spring on paper loader isn't sprung
Jul 27, 2009 | Dell Inkjet 720 Printer
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
Says add paper to large tray even though it is full
Depending on which large capacity feeder you have.
If you have the one that is on the bottom of the machine, make sure there is a gap between the paper in the front and rear of the paper tray, There is a black plastic guide in the middle of the tray that may be being caught by the paper.
If you have the large capacity feeder on the right side of the machine then most likely the black actuator that tells the machine the tray is full has broken or the sensor is bad,
Feb 12, 2009 | Toshiba E-STUDIO 650 Copier
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
HP 1210 All In One Printer
see this is the common problem i got so many query regarding this proplem ,you can easily solve this problem , when you placing the paper in paper tray be very carefull put very slowly inside when you feel a little bit of resistent stop it that mean paper is properly inside dont put so hard inside. bye
Aug 12, 2007 | HP PSC 1210 All-In-One InkJet Printer
Canon PC-920 Black and White Copier Logo
29 people viewed this question
old marine
old marine
