Question about Dell Inspiron 8200 Notebook
I have a Dell Inspiron 8200. The mouse does not respond. It slides down and to the left and then becomes inoperable. Is there any way to fix the problem? Could I use an external mouse?
    Guru:
  • 689 Answers
You can get some really cool tiny little mouse these days or even one with a ball on top that you rotate,ive got an optical one on my standalone,its got a cable but its pretty smooth.
But first try to configure the touchpad in your settings,thaths the most likely problem that you can most probably fix yourself
Posted on Sep 06, 2010
The cursor jumps backward in text. It jumps several lines up and down.It also does not respond to a simple left tap when I need it to open or close wish to delete something. I am not accidently doing...
Replace the mouse with a known good working one.
If you are not using a mouse (bad news) the touch pad may be failing.
In that case, an easy test and fix is to disable it in "Control Panel" then install a mouse in the USB Port.
If the problem is corrected then it is your touch pad.
Here is a link to the manual from Dell. FREE!
http://support.dell.com/support/edocs/systems/ins6000/en/om/D5181bk5.pdf
See Page 42 on disabling the Touch Pad.
Go to EBay and insert "6000 Dell Inspiron touch pad". It's cheap but difficult to replace.
Jul 24, 2011 | Dell Inspiron 6000 Notebook
My dell inspiron laptop's left click button isn't working as well as it use to, i think it maybe worn down, is there anyway i could get it replaced, and if so, where?
Simple solution with less cost is please use the external USB mouse.(Small size also avaible in market.) You are not mentioned the location where you are, Please locate the nearest Laptop service center for repair/replacement.
Try once with installing the Touch pad drivers.. .
Jun 28, 2011 | Dell Inspiron 1750 Laptop
My Dell Inspiron 8200 will not power
remove the battery and try again with ac adapter
Mar 19, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron E1505 Buttons on mouse NOT RESPONDING, Left or right.
run your comp in safe mode, if still not working, run 32 bit dell diagnostic using teh drivers disc, test touchpad, if still not working replace palmrest
Feb 21, 2010 | Dell Inspiron E1505 Notebook
Mouse pad on dell inspiron 1501 not responding smoothly to my request. I am very disappointed with my two year old dell. Need help asap.
This is a common problem with laptop touch-pads.
You will have to use an external mouse. You can purchase a USB mouse which should solve your problem.
Dec 30, 2009 | Dell Inspiron 8200 Notebook
Left mouse pad doesn't respond, or sticking
It's probably a hardware defect ,you can take it to an authorised Dell service center and they can make you a quote ,in the meantime you can use a USB mouse.
Apr 23, 2009 | Dell INSPIRON 6000 CENTRINO...
Mouse pad
you would be better off using an optical mouse that has a usb or ps2 connector ( depending on what your laptop supports ) usb would be better though less chance of pins bending as there are none on a usb connection ( at least not like a ps2 connector )
Also download the latest drivers for the touchpad and make sure that the scrolling options for or on the touchpad are not configured too thickly which will be in the touch pad settings.
Apr 15, 2009 | Dell Inspiron 8200 Notebook
Dell latitude 820 mouse driver
Whne you double click on the mouse in device manager, does it say "device not configured" or "unable to start this device". If it says "unable to start this device" try the mouse on a different computer to make sure it works properly. If it does then you probally have a software driver problem. Try contacting the mouse manufacturer or see if you can down load drivers from their site.
Jul 24, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron 8200 Notebook Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
