Question about Nokia 6030 Cellular Phone
CODE ERROR there is a code error in my hand set 6030 BL-5C 0670400417535N275G10421978.. PLEASE TELL ME THE SOLUTION AS SOON AS POSSIBLE..
  • 48 Answers
Where you getting this ERROR msg... is there any security code installed.. Please clarify.
Posted on May 13, 2008
Tip
How to put higher capacity battery into old Nokia Mobile Phones
As we all want longer stand-by and talking times with our mobile phones and sometimes get problems to get an original battery for our old Nokias, here is a tip for this matter:
Most of the former Nokia mobile phones use the battery with the model type number "BL-4C". There are some models using type "BL-5C". This "5C" model has more capacity and could also be used instead of the "4C" model. The 5C model is slightly fatter than the 4C one.
Using BL-5C needs with some Nokia mobile phone models a little modification (like 6100) while others do not (like 6260) and require a bit harder close of the battery lid. Cutting both edges on the batteries sides to fitting in the battery compartment is easy done. Charging process is not influenced and works accurate.
on Feb 28, 2011 | Cell Phones
Nokia 6233 charger not supported
Before you contact mobile repairing shop.check the battery because nokia battery BL-5CA and BL-5C are different.So, if the current battery is BL-5CA insert BL-5C, and follow as vise-versa.Otherwise contact mobile repairing shop.Thanks for visiting fixya
Mar 27, 2012 | Nokia 6233 Cellular Phone
I need a restriction code number to unlock my phone
Please specify your mobile model and your network.. Your mobile can be unlocked using the codes..This is the safe method of unlocking..If you need an unlocking code, get it from Prounlocking.com . Here you will get the unlocking service for your mobile at reasonable price..
Aug 05, 2011 | Nokia OEM BL-5C Li-Ion Battery with...
Low battery
sir the nokia n70 comes with BL-5C battery this batter has a complaint it will not cover 1 year lifetime. so the best way is to buy a new BL-5C battery and charge it initially for 8 hours continuously..
Dec 06, 2010 | Nokia N70 Cellular Phone
About nokia battery BL-5C
Please contact nokia care service center.
Jan 15, 2009 | Nokia 1100
I would like the unlock code for my Nokia Model: 6030 Type: rm-75
These Nokia Unlock Codes are Generated For Nokia 6030 with IMEI: 010892001344298 (DCT 4) Locked to Provider AT&T(Other DCT4) in U.S.A. and will only work with this phone!
#pw+445257662374164+1#
#pw+035553450307267+2#
#pw+096863516430370+3#
#pw+019813335730321+4#
#pw+145534364337643+5#
#pw+344446364266354+6#
#pw+283915302101420+7#
How to Enter your Unlock Codes
Recommended CODE :#pw+283915302101420 +7#
  1. Remove SIM CARD !
  2. Type #
  3. Then press the * key 3times (you should get a "p")
  4. Then press the * key 4times (you should get a "w")
  5. Then press the * key 2times (you should get a "+")
  6. Then enter: 283915302101420
  7. Then press the * key 2times(you should get a "+")
  8. Then enter: 7
  9. Enter: #
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
  • If you get CANNOT UNDO RESTRICTION your phone cannot be unlocked remotely and you need to mail in your phone!
  • If you get CODE ERROR the above codes do not work for your phone DO NOT ATTEMPT TO ENTER THE SAME CODE AGAIN
    Repeat above instructions, but with the numbers from code 1 (#pw+445257662374164+1#) if code that does not unlock your phone STOP! . You need to Mail-In your Nokia phone to have it unlocked
Jan 06, 2009 | Nokia 6030 Cellular Phone
Nokia 6030 Security code required???
i have a nokia 6030 phone and whenever iam trying to restore my factory settings by the default code 12345 its not working properly
Sep 13, 2008 | Nokia 6030 Cellular Phone
Any clue what error code 6030 is?
I had the same problem. Pull the Fuser and check Conector.Sometime pieces of paper inside the Conector raises an error.
Please Rate .
Jan 11, 2008 | Kyocera FS-2000D Laser Printer
Regarding BL-5C battery blast
Here's the list of phones that should replace their batteries Nokia 1100, Nokia 1100c, Nokia 1101, Nokia 1108, Nokia 1110, Nokia 1112, Nokia 1255, Nokia 1315, Nokia 1600, Nokia 2112, Nokia 2118, Nokia 2255, Nokia 2272, Nokia 2275, Nokia 2300, Nokia 2300c, Nokia 2310, Nokia 2355, Nokia 2600, Nokia 2610, Nokia 2610b, Nokia 2626, Nokia 3100, Nokia 3105, Nokia 3120, Nokia 3125, Nokia 6030, Nokia 6085, Nokia 6086, Nokia 6108, Nokia 6175i, Nokia 6178i, Nokia 6230, Nokia 6230i, Nokia 6270, Nokia 6600, Nokia 6620, Nokia 6630, Nokia 6631, Nokia 6670, Nokia 6680, Nokia 6681, Nokia 6682, Nokia 6820, Nokia 6822, Nokia 7610, Nokia N70, Nokia N71, Nokia N72, Nokia N91, Nokia E50, Nokia E60 The battery name is BL-5C
Aug 15, 2007 | Nokia 1100
Nokia 6030 Cellular Phone Logo
103 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
