Question about Saeco Royal Cappuccino Espresso Machine
When I turn my saeco royal cappuccino machine on then it tells me that the dregdrawer is full but it isnt full. So can anybody tell me whats the problem? Maybay the drawers sensor is broken or something?
Drawer sensor (activated by horizontal tab on left side of drawer) works on the weight (like a mini scale) of the drawer when full. The motion of the sensor can become restricted due to grinds limiting the movement upward to the default position.
If 'stuck', the sensor thinks the drawer is heavy and therefore full.
Clean it (old toothbrush, hot water, steam run from your spigot) so it moves freely and your problem should be solved.
Happy brewing!!
Posted on Nov 06, 2010
My Saeco Royal coffee machine is displaying 'empty water container' and it is full - what is the problem
Is the floating magnet in the water reservoir floating ? If yes, you will have to check:
1) the micro switch which is located just beside the magnet (open the machine to check it with and ohm-meter) Check it with a small magnet that you have
2) if the micro-switch is OK with a hand-held magnet the floating magnet may be de-magnetized
3) if everything above is OK, the input on the control board is perhaps defective
Mar 23, 2012 | Saeco Royal Cappuccino Espresso Machine
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
I have a saeco roayl professional espresso machine
Check behind the drawer, there might be some grinds preventing the it from activing the microswitch.
Jan 25, 2010 | Saeco Royal Professional Espresso Machine
My Saeco Royal Cappuccino Coffee machine says "refill water tank' when it is already full. I only use filtered water and have descaled the machine. How can I fix this?
This sounds like the water sensor needs replaced //Also make sure the inside float is not stuck in the down posistion!
I hope this helps!
Dec 13, 2008 | Saeco Royal Cappuccino Espresso Machine
Dregdrawer. miss.
Make sure the machine is clean of coffee grinds. Mine has a nasty habit of dropping them behind the dregdrawer instead of in it. Remove the central unit and give it a good clean. The dregdrawer should then slide back fully into the microswitch.
If this doesn't work, you've probably got a dud microswitch.
Nov 20, 2008 | Saeco Royal Professional Espresso Machine
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
"dregdrawer" is full
You must have the dregs box out of the machine 5-10 sec and the machine have to be power on.
If it still not get to work then try this:
Make sure the pin on the side not is worn, the pin goes to a microswitch in the machine.
If it is worn then try to put a tape on it to see if help.
Best regards
/Mirran
Sep 11, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Cappuccino Espresso Machine Logo
332 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
