Question about Coleman Powermate Premium Plus 6250W Portable Generator
I have a Powermate Blackmax 5250 portable generator. Where should the choke be for best operation during starting, and running?
CarlGehrke
  • 169 Answers
SOURCE: powermate pm0545005 generator engine runs but no power out
I posted a general "how to" about troubleshooting Powermates here.
Don't forget to rate answers you like,
Carl
Posted on Dec 05, 2008
CarlGehrke
  • 169 Answers
SOURCE: Coleman Powermate 6250 only runs with choke closed/air restricted
Hi folks,
You're both right to think that these engines were not intended to work at extreme low temps and that's a factor here.
The dry black soot on the plugs is probably just oil getting into the intake thru the breather, maybe check the air cleaner.
On some of the generators I've worked on there was a small plate in the air cleaner cover that slightly restricted air flow into the carb for low temp operation. Both of you might want to try getting a cardboard box quite a bit larger than the generator, cut a couple of holes in it to let exhaust out, and put it over the generator so that the air going into the intake gets heated a little bit by the engine. You'll want to monitor the generator pretty closely so I wouldn't recommend this overnight. You both should also be extra careful about the right amount of oil in the sump and changing it more often than usual.
My thoughts are with you folks,
Carl
Posted on Dec 15, 2008
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
protek480
  • 1714 Answers
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
Posted on Aug 01, 2009
  • 3 Answers
SOURCE: plug wiring diagram for 240v outlet 7000w blackmax
Probably its similar to the wiring on page 31 of this manual (pdf page 28) of this manual, reference NGK-7000HE: http://www.electricgeneratorsdirect.com/manuals/NGK%20Generator%20Honda%20engine.pdf
Posted on Mar 14, 2010
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Plug fouls out turns black and starts to backfire
What does the oil look and smell like? Also what conditions is it been ran in lately, and what fuel are you running?
Sep 12, 2014 | Coleman Powermate Premium Plus 6250W...
Powermate generator 3250 runs for hours then chokes out runs rough
If it runs for hours under the same a mount of load then, chokes down, make sure fuel lines are fully clear, it may operate with a full tank of gas then when the weight of the fuel in the tank gets less has a problem. When it chokes out fill the gas back up and see if it works again. Also make sure the choke butterfly is not closing again whilst hot. I don't know how many hours are on it, but a decarb may be in order, especially if it runs for hours no issues
Oct 27, 2012 | Powermate Portable Generator: 3250-Watt...
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Should I cover my generator while it is running
no possible to over- heat unit the engine needs air to stay cool also the covering can catch fire if u want to protect while out running in elements a make shift tent style cover open on bottom pitched type over top, mine is left out all year my daughters are grown so i use their old little tykes building it fits inside has enough room for air and the building protects it from the elements as well as hiding its appearance
Feb 25, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 6250 generator only runs with Choke on? pull
Cbronson
how old was the fuel in the tank and carb bowl? This could have built up varnish and make the float heavier
Another issue that my customers bring in are 4 stroke generators that have 2 stroke fuel put in tank.
Jan 14, 2009 | Coleman Powermate Premium Plus 6250W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
93 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
