I have a Panasonic SC-PT560EB-K. all speakers work on the test tone but the 2 smal "surround" speakers appear to just make an interference noise, theres no actual audio from the tv/ps3 coming through them. any ideas?
  • granty78 May 13, 2008
    how dim am i???
    nice one shaggy, thanks alot
    Genius:
  • 1,224 Answers
Goto game mode on your receiver this is full surround all out speakers working your probably set on movie mode which at different accoustics shuffles to different speakers to give surround sound
Posted on May 13, 2008
Sony STR-DE475 - no surround sound
Thanks for all the info. It appears that the Receiver requires service as there is no test tone also. However, please clean the speaker cables and speaker jacks and reconnect. Also, try the steps mentioned in the link below.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C216020&fes=true&mdl=STRDE475
Sep 26, 2009 | Sony STR-DE475 Receiver
Not all the speakers are working despite ensuring the cables are
There is a button that says -Mix 2CH - make sure it does not say Mix 2CH ON, or you will only get 2 channels when watching DVDs. This Panasonic, as well as legions of other home theater systems, are more limited than they seem. The SC-HT500 can give you surround when watching DVD's on the unit, but you will not be able to get full surround for your TV, because the Panasonic does not have the right digital inputs.
-Tha Mp3 Doctor
Feb 21, 2009 | Panasonic SC-HT500 System
Rear speakers not working
Some TV is not broadcast in surround... you will not get back speakers from TV, only from DVD.
Feb 16, 2009 | Panasonic Home Theater System System
Add 2 speakers outside on a 6 speaker surround sound and hear all
You won`t get surround sound mix with 2 speakers, you can have a 2nd zone but this will only play a "Stereo Sound" if you have that playback option with the SC-RT50, what you will need is a speaker selector switch or better known as an A & B switch, this will ideally run from the front left and right speaker output of the receiver into the A & B switch then run into each pair of speakers inside or outside, what is common nowdays are receiver that are known as 2nd zone connections where you can have 2 sets of speaker in different rooms, unfortunatly the SC-PT50 does not have this option.
Feb 03, 2009 | Panasonic SC-RT50 System
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Set up the Panasonic SC-PT450 and followed all the various instructions. Am using the surround sound in conjunction with a Panasonic TV bought at same time (50" plasma) but can't seem to get sound out...
Are you sure you're using a source material that is surround sound? Most TV broadcasts are still only stereo.
Also with surround programmes, the rear speakers are only used for the surround effect so will only make sound when the sound source is supposed to be behind you.
Jun 25, 2008 | Panasonic Televison & Video
Possible broken speaker
You must determine if subwoofer amp or speaker are bad.Take the good surround speaker and move it to the bad side.If the good speaker does not produce audio the the amplifer is bad.If you use the good speaker in either surround output and it works then your speaker is bad.If you take the small speaker apart the panasonic part number is stamped on the magnet.Locate a service center that will order it for you.
Mar 13, 2008 | Panasonic SC-HT730 System
Dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Jun 13, 2006 | JVC MX-DVA9 Shelf System
85 people viewed this question
 Grubhead
Grubhead
