Question about Elite Saniflo SaniCompact- SaniCompact One Piece Macerator Toilet
Involuntary flushing operation occurs every 10 minutes
i was having same problem with my sanicompact48,it was flushing continuously after few minutes.i opened and cleaned every thing still it was the same thing.and i noticed irreguliar flushing due to SOLONOID VALVE.just replaced and works fine.yo can order by phone # 1 800 571 8191 to "saniflow".tale them your problem and your toilet model.
good luck
garry
Posted on Jun 05, 2012
  • 50 Answers
The valve is jammed and flushes as soon as the pressure is up.
Posted on Sep 06, 2010
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Heaters slow at warming up
In normal circumstances the heater wouldn't begin blowing warm air until the vehicle has travelled 5 miles - call it 5 minutes. That's because the thermostat only begins to open at around that mileage/time and allows coolant to circulate around the engine. Before that - there just isn't any warm coolant in the heater matrix.
After 10 miles/10 minutes of normal driving the engine will be at its correct operating temperature and the coolant will be hotter - as will the circulating coolant in the heater matrix. That's when the heater blows the hottest air.
If you're sure that the heater has lost efficiency it may be due to air being trapped in the heater matrix/coolant system, or a blockage caused by limescale/engine corrosion within the heater matrix itself.
To remove any trapped air, set the heater to maximum, remove the radiator cap/coolant bottle cap and let the engine tick over for 10 minutes.
If the heater matrix is blocked/partially blocked, drain the coolant system, refill with plain water, set the heater control to open .. and let the engine tick over for 10 minutes. Drain it again.
Refill again with plain water and add a can of 'radiator flush'. Follow the instructions on the can of 'radiator flush'.
Drain again and refill with coolant/water.
If the heater is still inefficient then the only option is to replace it - and that's not an easy job.
Jan 21, 2016 | 2006 Nissan Navara 2.5
Involuntary mouse movement
Are you using wireless mouse? if so, try replacing battery. Still not working? replace mouse. If USB mouse, try changing the mouse pad. Still trouble? try different USB port and update BIOS.
Jan 23, 2012 | Computers & Internet
2006 Ford F250 Super Duty King Ranch Diesel four wheel drive automatic, intermitent front brake drivers side binds and drags, caliper gets too hot to touch. OK after it cools off, 10 to 20 minutes. ...
About the only thing left is to replace the caliper. I've seen a few times, but not common. Piston gets bound on corrosion in caliper and doesn't retract completely.
Mar 09, 2011 | 2000 Ford F250 Super Duty Crew Cabs
My nintendo Wii says: "Error occured.
One, is the disc scratched?
Two, What Game?
Three, Try unplugging the power cord from the wall and Wii, and wait 10 minutes, and plug it back in. Should Work Like new.
Jan 21, 2011 | Nintendo Wii Console
How does download work?
A download is when you retrieve a file from an external storage location. This could be a local drive you have or from a provider via a website. Typical downloads are those that are music files, drivers for devices, and documents. There are also voluntary and involuntary downloads. Voluntary is when you choose to add a driver or document to your device. Involuntary is when a cookie or other file is added to allow functionality of a program or website. Usually to download any of the above (except involuntary) you will be given a DOWNLOAD button to click on or otherwise choose. If operating a Windows based operating system you will be asked to SAVE or RUN the file. Saving the file places a copy on your computer to be opened, ran, etc. at a later time. Choosing RUN places a copy of the file in a temporary location on your PC and then executes the action such as installation of a program. When the installation is done if you chose RUN then the temporary file is automatically deleted. If you chose SAVE then even when you execute the file action the file stays on your computer. Be careful of what you download and the source of the file. Some downloads contain virus or other malware that will negatively affect your computer. If you utilize virus software the best option is to SAVE the file and then scan it via the antivirus software prior to executing the action. Final comment... Limewire, Youtube, Bittorrent etc are notorious for INFECTED downloads... you should be very cautious if you use these sites. Manufacturer sites like HP, Dell, Apple and sites like CNET are safe bets for files and drivers.
Jun 30, 2010 | Computers & Internet
Involuntary accelleration in my 96 honda accord 2.2L
Oxygen sensor might be going bad hondas tend to have two of them an upper and lower. The throttle sensor and or cable might be on the fritz too. The ECU tries to adjust everything based on driving patterns and it can do some strange things if other people drive it besides yourself you might want to reset it on hondas I believe you turn the key to acc hold the brake in for 5 to 10 seconds turn it to off then start it it not 100% on that memory is a bit off since I havent owned a honda in about 4 years. The gas pedal might also be sticking a little bit make sure its free and clear and presses in and out smoothly when stopped and parked of course.
Jan 11, 2010 | 1996 Honda Accord
Toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Jun 20, 2009 | Toto Drake ADA Compliant Toilet with...
Elite Saniflo SaniCompact- SaniCompact One Piece Macerator Toilet Logo
558 people viewed this question
Top Elite Home Experts
Donni Steen
Tom Chichester
Are you an Elite Home Expert? Answer questions, earn points and help others
