Question about Minolta Di3510f Bizhub Copier
Set ip address
How i can set ip add. fo this copier with aprinter controller?
plz. advice
    Problem Solver:
  • 7 Answers
You will need to enter admin mode.
To do this select utility, admin management,the passcode should be 12345678 if not try 00000000 & ok.
Once in admin mode select admin 2, network set.
Press basic setting, press DHCP and set to IP input & ok.
Select IP address & input your desired ip address & ok.
Do the same for your subnet & gateway addresses then press enter, it should then ask you to reset the printer by the main switch ( not the one on the control panel ).
Once restarted you can check if the settings have been stored by outputting a config sheet.
Hope this helps.
Posted on May 21, 2008
How do I add a printer to the network?
How to create an IP address into your Printer
1, Connect to LAN network
2, Power ON the Printer.
3, Select MENU Button
4, Go to System Settings, then select Network Settings.
5, You can see TCP/IP , View IP ,etc.....
6, Type Your Printer IP address, Subnet Mask, GateWay, etc...
7, That's All......
In different Printer settings will be different.
Now You can add printer into your computer
Go to Control Panel--> Hardware and Sound -->Device and printers -->Add Printer-->Add network Printer-->"If no printer were found" Select "The printer that i want isn't listed" --> Add printer using TCP/IP--> Type your Printer IP address--> Now you can install printer software...
Thanks
Oct 10, 2012 | Canon imageCLASS MF4370dn...
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    I CANT SEND MMS IN MY K770I
    U need to activate mms service by calling ur service provider and these are the settings fo the same.
    Press “Menu” and go to “Messages”
    Select “Settings” and select “Multimedia messages”
    Select “Network settings”
    Select “Options” and select “Add new”
    Enter the profile name as “service MMS”
    Press “Ok” and select “Options”
    Go to the “Settings”
    Enter the details as follow:
    1. Homepage: Define homepage here.
    2. Bearer: GPRS
    3. GPRS settings
    APN: Define acess point name here.
    User ID: <blank>
    Password: <blank>
    4. Proxy settings:
    Proxy settings: On
    IP address: Define Ip add. here.
    Port: 9210
    5. DNS settings: <Leave it as default>
    Press “Ok” to save the settings and return to the main settings and select ‘Activate”
    MMS configuration completed
    Good luck
    Jun 30, 2010 | Sony Ericsson K800i Cellular Phone
    Canon imagerunner c3100n Howe do I remove
    Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
    Oct 30, 2009 | Canon imageRunner C3100 Copier
    How do I create/set up the IP address for a toshiba estudio 353 copy/fax/scan unit?
    On control panel press "user functions" , then select admin tab, press password and type password (default is 123456),press network and then ipv4. There you need to type in free IP address, subnet mask and gateway.
    For more ask your network admin.
    Oct 13, 2009 | Toshiba e-Studio 282 Printer
    Scanner installation
    I WANT T INSTALL SCANNER SOFTWARE IN MY SYSTEM
    Dec 09, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
    Dear Sir Plz Help Me Plz.
    If the button on the touch screen is not visible for the network settings in the administrator settings there is definately something going on. Try connectng to the web interface by typing the current IP address of the copier into the address bar in Internet Explorer. If you do not know the IP address that was assigned to it then Google for Angry IP Scanner, download, and install it. Let it scan your network and find the IP address that way. If you have the right IP address nd cannot access the IP then try it in Mozilla Firefox. You PC must be in the same IP range for any of this to work.
    Once you get into the web interface you need to hit LOGOUT as you are in public mode. Then log back in as administrator. The default password is 00000000 or more likely, 12345678. YOU MUST LOG OUT OF ADMIN MODE. DO NOT JUST CLOSE THE BROWSER WINDOW. This will lock up the control panel and cause problems.
    You can change the IP address from the web interface in admin mode.
    If none of this works then contact me and I will go further. Hope this helps.
    Oct 05, 2008 | Office Equipment & Supplies
    I cant connect my wireless laptop tp my comp.
    Let me know the settings of your Router if needed IP address?
    Yes - add your IP address into Network Connection.
    No - obtained the setting in your Network Connection.
    How to Add or Obtained the setting s of your IP address:
    - goto Control Panel
    - Double Click Network Connection
    - Rigth Click then Properties the Local Area Connection
    - Select Internet Protocol (TCP/IP) and select Properties
    - Under General Tab they have choices to add or obtained settings.
    Sep 20, 2008 | Linksys Wireless-G WRT54G Router
    Canon Image runner 5000
    Have the IP addresses changed ?
    Is the copier set with auto IP ?
    If either is Yes you will need to set the machine IP address.
    Set the IP-Subnet mask-Gateway adresses
    you can do this by pressing the additional functions button
    ( the* button That is in a circle)
    then id management (bottom L/H col)
    then network settings (2nd to top R/H col)
    then protacol settings
    then TCP/IP settings
    Then change these settings to the desired settings
    Then go to your computer and make sure the print driver has
    the same settings
    Go to your computer
    Go to START
    Go to CONTROL PANEL
    Go to PRINTERS and FAX
    Then either change or check settings or add a new printer
    If you need further help please get in touch
    thank you
    Feb 20, 2008 | Canon imageRUNNER 5000 Copier
    666 people viewed this question
    Top Minolta Office Equipment & Supplies Experts
    Adorjani Laszlo
    Norman  J Weimar Jr
    Norman J Weimar Jr
    David Burkhart
    David Burkhart
    Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
