Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
After replacing circuit board in Mr Slim model MSH17TN, unit won't respond to remote (it displays as if communicating but no beep. Unit works using Emerg op switch. What's wrong?
  • 6 Answers
SOURCE: no heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Posted on Nov 14, 2007
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 8 Answers
SOURCE: Mr Slim air unit is blowing out dirt into my room.
Simple matter of cleaning the unit. You have to clean the filters, the coil and around the louver.
Posted on Jun 10, 2009
  • 340 Answers
SOURCE: mr. slim air conditioner does not cool.
maybe just a cleaning
Posted on Jun 19, 2009
  • 587 Answers
SOURCE: compressor won't switch on, have tried reset
If you have any experience in working with electrical systems, you can, but if not you should call a service technician.
First being very careful, check to make sure contactor is engaging.
Then check to see if you have the same voltage across all three wires on the compressor side of the contactor, assuming this is 230 volts, check T1 to T2 should have 230 volts, then check T2 to T3 should have 230 volts then check T1 to T3 should have 230 volts. If you have 230 volts to all 3 wires then the compressor is bad probably an open winding and needs replaced. Before replacing the compressor you need to check the resistance (with an ohmmeter) between all 3 terminals at the compressor. In order to do this you need to disconnect all power to the unit and ohm the compressor terminals from T1 to T2, T2 to T3 and T1 to T3 they should all have the same resistance if they do then the windings are good and the compressor is locked up, if one of the the windings is different then the windings are bad, either way the compressor needs replaced.
Posted on Nov 10, 2009
How do I get MR Slim out of standby mode
if unit is hard wired try turning circuit breaker off and then back on
Feb 14, 2015 | Mitsubishi Electric Mr Slim E12C26426...
How do i Turn off the beeping sound from mr slim ac unit? I've read all the manuals and searched the Mitsubishi site and the net extensively. Each time the unit is turned off or on, it emits a loud...
It requires surgery to remove the beeper :) seriously, find a local nerd to go in, not hard to do, and yank out the little piezo buzzer. I've had customer that wanted the same, factory said sorry no dice.
Sep 24, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
We have a Mitsubishi Mr Slim air conditioning unit, i've checked the circuit breaker, the remote works but the unit will not engage.
DOES IT DO ANYTHING I THINK ON THE RIGHT SIDE IF YOU HAVE YOU BOOK IT FLASHES ERROR CODES IF YOU HAVE THE COVER OFF
Sep 18, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
The unit does not respond to the remote, it seems that there is no power going to the unit. Have checked the service panel, replaced the bateries in the remote and I have tried the emergency start in the...
Check fuse in the AC machine panel. If power is available and still it does not respond, may the micro controller or infra-red receiver problem.
Take assitance from the service provider
May 27, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim split system with no display on remote control or unit display.
Mitsubishi Mr slim comes with no diplay on the indoor unit but there is small display on th eremote unit.for further help kindly send your air conditones complete model
Jul 09, 2009 | Heating & Cooling
Controller not working
The units were set up as master/slave by removing a jumper on the indoor board of the 0V unit. The CENTRALISED CONTROLLER display was removed by changing one of the indoor boards dipswitch settings.
Jun 10, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
What is the code p3 at Mr Slim thermostat
Signal transmission error (Remote control does not respond to indoor unit)
Causes:
Bad contact of transmission wire
Signal transmitting/receiving circuit is abnormal
Wrong operation due to noise interference by another appliance
Mitsubishi recommend replacing the transmission cables, the controller or the indoor board. Had the same problem myself one, I ran new temporary transmission cables. The unit ran no bother. Swapped the transmission cables for the original and the fault disappeared.
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
Mr.slim thermostat flashin and display p3
Causes:
Jun 10, 2009 | Heating & Cooling
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
122 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
