Question about JVC Video Cameras
How can I clean the heads of my JVC GY-HD250 without a headcleaning tape?
  • 2 more comments
  • lindop_tim Sep 06, 2010
    Yes, but is it as good as using a head cleaning tape? Any precautions I need to take?
    Also, how do I get to my heads? What do they look like? Am I risking damage hand-cleaning?
    How can I access the heads?
    How can I access my heads?
  • 11,896 Answers
Rubbing alcohol and a cotton swab
Posted on Sep 06, 2010
  • Nate Stansfield
    Nate Stansfield Sep 06, 2010
    Make sure cotton swab aka q-tip is not soaked to the point that it is dripping alcohol. Just wet but not dripping. Then clean the head, make sure to get all of it. The cleaning tapes have the same alcohol in them but cotton swabs work much better I think.
  • Nate Stansfield
    Open up the tape door, you will see where the tape contacts are. This is the head, you can clean it with rubbing alcohol and a cotton swab.
I need a headcleaner for a compact vhs camcorder modle gr-sxm38u
Umm they still make these things so if you cant find they do sill have the cleaner its just been renamed its called cd cleaner take it and open the tape deck and with a lint free cloth wipe the head and let dry
Mar 10, 2014 | JVC GR Video Cameras
JVC GR-DVL310 minDV camera plays with Red stripes or bars accross video..
You probably got a piece of q-tip stuck in the video head. try to run a chamos stick over the small pickups at the base of the drum from side to side, never up and down and you should be able to clean out the residue and fix your problem.
Jul 30, 2008 | JVC GR-DVL310 Mini DV Digital Camcorder
Video noise on jvc gy-dv500u
I have the same camera with the same problem.
Mar 09, 2012 | JVC -GY-DV500 w/lens, VF, Fuji 14x1:...
I was using my dcr-h28 minidv cam yesterday and an error message stating dirty head came on the screen. So, I took a drop of alcohol on a q-tip and cleaned it up like I'd do on any other recording head......
first u buy a headcleaning tape and put it 5 second play then cheak again.the same complaint showing again u must go a repairing shop may be ur head gon .any doubt call 00971503853766
Jul 03, 2009 | Sony Handycam DCR-HC28 Mini DV Digital...
Video heads clogged - don't get cleaned with cleaning cassette
This needs to be solved at the shop if your product is under warranty.
ESLE
If you are adept at opening gadgets do this
Get a bottle carbon tetra chloride
Dip an end of ear buds and clean the heads without touching any plastic parts. Carbon tetra choloride dissolves plastic. The head look like a small "_" on the cylinder. There will be 2 of them
Babdi
Apr 19, 2009 | JVC GY-DV5000U Mini DV Digital Camcorder
Will not eject tape
If your camcorder is JVC GY-DV550 and having a tape jam problem, It could be mechanical problem such as pinch roller or tape may be loose inside. I will try this just in case of loose tape. At VCR mode, press FF serveral times then REW same. Now try eject. If that did not work, you should take it to professional service facility near you for further diagnostic. Good luck, -james
Mar 27, 2009 | JVC GY-DV550 Mini DV Digital Camcorder
Head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
May 31, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
"No DV Input"
get a head and path wet cleaning and reset and recheck again
Oct 27, 2006 | JVC GY-DV5000U Mini DV Digital Camcorder
Blue screen on playback footage
it seems to be a simple problem of dirty video head. check again after cleaning it.
Oct 26, 2006 | JVC GY-HD100 Mini DV Digital Camcorder
Video Cameras Logo
37 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
