Question about Sony SLV-N750 VHS/S-VHS playback VCR
Sony slv 715ub no stereo sound on tape playback
When first turned on the stereo sound from the tape play works for a couple of seconds and then cuts off with a click, and then does not work again... linear sound works fine? any ideas
Hi, i have a Panasonic dmr-es30veb DVD ram recorder/VCR and i cant record one channel while watching another, as you can tell i am not at all technically minded and if you can help i would be grateful many thanks Eileen.
Posted on May 13, 2008
HOW DO I RECORD WITH A SONY SLV-N77 MANUAL DOES NOT HAVE ANY DIRECTIONS
Looks like a great brand with good features for the price.
  1. Connect Video & Audio Cables to a video signal source
  2. Connect Power Cable
  3. Turn on VCR.
  4. Insert a blank tape in the VCR.
  5. Note - A Broken Tab on the back of tape will prevent recording. This is called Write Protection.
  6. Cover the tab hole if you want to record over old video.
  7. Press RECORD on the VCR remote control.
  8. After a minute, press Stop, then PLAY to see recording.
  9. Cheers
Aug 18, 2014 | Sony SLV-N750 VHS/S-VHS playback VCR
Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Dec 06, 2012 | Sony Televison & Video
Our Sony Video cassette recorder model SLV_N750 won't play??? The tape is going into play, but the reels are not turning. The VCR starts with a snowy picture and guickly stops and won't play?
The problem is the idler assembly or the black square belt that drives it, this will cause the vcr to shutdown preventing tape transport. The vcr will need to be dismantled for repair, I recommend a tv technician to check your machine with an estimate.
Jan 08, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Cassette jammed, system cutting out.
Take cover off and turn the loading motor until it come out.
May 24, 2010 | Sony SLV-SE730 VHS VCR
Intermittent loss of video (mimicking dirty heads symptoms)
Control head dirty. That is where the tape counter picks up the frame pulses.
Jan 18, 2018 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Sony SLV-N60 stopped playing suddenly
Sounds like you have a head-clog. You can purchase a VHS Head Cleaner at Radio Shack for $5.00. If that doesn't work repairing your VCR is not cost effective when you consider that you can purchase a new VHS/DVD combo deck for under $125.00
Aug 17, 2009 | Sony SLV-N60 VHS VCR
Sony VCR ''Eats the Tape'' Model SLV-N750. It plays and records but doesn't release tape. It does not repond after I try to run forward or back and does not advance on ''Play'' but shuts off. Is there any...
If this unit is 4-7 years old then TOSS it. As time goes by the rubber gets soft and the units timing gets whacked. Repair will be more than what it's worth , unless your emotionally attached to it ...
Please rate!
Mar 13, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-940HF automatically ejects tape.
1st try a different tape.
If it's the same, listen carefully for unusual noises, clunks, grinding, etc. when the tape goes in. Is something binding?
With the tape out, look inside the door, see if you can spot anything in there that shouldnt be there such as a small toy, money, playing card, sandwich, bits of food? Those are the usuals.
Turn the vcr upside down and holding the tape door open, tilt it so if there was a foreign object in there, it would fall out.
Oct 16, 2007 | Sony SLV-940HF VCR
Sony SLV-N750 VHS/S-VHS playback VCR Logo
159 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
