Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Insinkerator badger 5: plate rotates freely but when switched on it only hums. The blades do nothing.
  • Ace Hardware Master
  • 43,501 Answers
The motor has gone bad
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Posted on Sep 29, 2010
Garbage disposal makes loud noise, nothing stuck, blades turn freely
Bearings in the motor are worn enough to allow the grinder plate to rub against the side of the chamber.
Apr 10, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger insinkerator, 1/3 HP does not start. Please help...i try the red button and didn't work...the blades aren't rotating....
Use wood broomstick handle down into disposal.
Wedge broomstick against side of sink opening and rotate blades free.
Or use allen wrench on bottom of disposal to free cutter blade.
If blades rotate freely and disposal has power, and reset is not tripped or will not reset, then disposal is bad.
I wrote ez disposal replacement steps:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1/2 HP garbage disposal not working. Motor hums, blades are not rotating. I can rotate the service wrench with tension.
I would keep working the impeller back and forth with wrench while running hot water thru disposal until it turns freely. You can see if there are any small bone fragments or other debris in grinding chamber and removing with long needle nose pliers. Good luck. Thank you.
Apr 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal only hums. I can turn the blades inside so there is no food stuck. I know there is a reset button but cant locate it.
I had the same problem, it was just humming, then after a few second the on board circuit breaker would cut out. After a little while I could hit the reset button and it would just hum again.
It turns out that the base of the disposal was jammed. There are 2 blades on the top that should spin freely, but the base plate that the blades are attached to also spins. In fact, that's what the motor drives. The two blades on top are not powered, they just flip back and forth as the base spins. So get a broom handle or a strong wooden spoon, stick it down in there, and try to pry the base plate free so it spins. That should do it.
Oct 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator Badger 5 - Does not turn, just hums. Turned on and quickly rotated with hex tool and it started but would just hum with out the initial turning.
If it turns freely with the hex key, but won't start,without help, you probably have start winding switch problems. As these are not very expensive, I would buy a new disposal. You can purchase a 3/4Hp for near 100.00 , so it isn't worth spending a lot of time on an old one, especially if it is older and corroded.
Oct 01, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: It hums but doesn't work. The wrench moves freely ...
If the blades move freely with the wrench and stick and motor hums then it sounds like it is time to replace the unit. Have you tried the reset switch? If it is humming than it is probably not tripped but worth a try. Hope this helps.
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
MY BADGER 5 HAS POWER TO IT AND ATEMPTS TO TURN BUT WON'T, WHEN YOU TURN IT MANNUALY IT SEEMS GUMMED UP HARD TO TURN,AL OF THE BLADES ARE FREE AND NOTHING IS IN IT
Be aware that the wheel that makes up the entire floor of the grinding chamber is the part that rotates. There are two lugs mounted on this wheel that rotate freely, but they are not driven by the motor. There's a hole in the bottom middle of the disposer where you can insert an allen wrench (there may be a special disposer tool already in the cabinet) and turn the motor manually. If the motor does turn freely, but the disposer still hums and doesn't stat, that'll mean there's a problem with the motor's starter circuit. You or a motor repair shop could open up the motor and check the resistance of the windings, the centrifugal starter switch, etc., but your best value at this point, especially with an entry level model such as a badger 5, is to replace the disposer. If you get another one made by insinkerator you can install the new one in like three steps.
Dec 21, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator
The capacitor is probably bad, that's what makes it start to rotate. It's under the metal case on the side of the motor. Pull it off and take it to a motor to to replace.
Jul 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
274 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
