Question about Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard
Using compaq f700 series. Cd rom is not getting detected. >not in device manager >not in bios boot menu >have tried upper filter lowerfilter thing..its not there in registry >have tried edit reg settings fix..nothin wrked >have tried reinstalling os, nothin worked >ONLY some MAESTRO genius can help me out..coz ive really tried my drive on some other laptop and its working.
E500
SOURCE: boot sequence problem
bios satup key
Posted on Jan 14, 2008
carlosmoya
  • 58 Answers
SOURCE: Cd rom
Is this a new CD-ROM? Usually if the BIOS cannot see the drive it's a problem with the jumper setting on the back of the drive. Try setting the jumper to cable select. Let me know if that helps.
Posted on Jun 24, 2008
hardkiss69
  • 43 Answers
SOURCE: UNABLE TO DETECT CD/DVD ROM
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Your registry might be corrupted (code 19)."
You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 28, 2008
biglala
  • 50 Answers
SOURCE: i have a compaq presario v6000 laptop.
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
a37
Posted on Dec 25, 2008
Geekman
  • 32281 Answers
SOURCE: PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Posted on Sep 14, 2009
HOW TO DETECT THE CD ROM USING PHOENIX ROM BIOS PLUS VERSION 1.10 A02
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
If the cd rom is not being detected ?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 28, 2013 | Computers & Internet
My Presario F700 won't recognize it's dvd drive. IIt doesn't show in the boot options, so it would appear that the BIOS is not recognizing it. I have tried the drive in another laptop and the BIOS detects...
Try going into "control panel", find "device manager" and right click on it. In the list, find cd-dvd rom drivesand click on box at right side of line item. It should dop downand show your device. right click on it and you shoud see "enabe" or "disable". If it says enable, click on that.
Mar 15, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
It doesn't read any cd's or dvd's as if it doesn't exist
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer
Mar 09, 2011 | Acer Computers & Internet
.i have got a preserio
CD/DVD issue
> is it an internal cd/dvd drive or external cd/dvd drive
> INTERNAL DRIVE
> ask for lights or glowing (optical drive lights)
> check whether the cd/dvd is getting detected
> For that click on my computers
> c- Drive and d- drive and also cd-dvd need to be detected (but in this case you will not find cd-dvd drive)
> Now follow the LOGIC FLOW
> Now need to do SYSTEM RESTORE (start> all programs> accessories > system restore)
> After the system restore
> switch off the laptop
> Now try and get in to the BIOS
> need to do BIOS default and BIOS update
> Now un-install and re-install the drivers (CD/DVD drivers)
> Start search > type Regedit
> Now try to locate H-KEY-LOCAL-MACHINE
> There would be a positive symbol (+) beside this
> Just need to click on that (+) symbol
> locate a folder which says SYSTEM
> Beside the SYSTEM there would be a (+) symbol
> Now locate CURRENT CONTROL SET option
> Now there would be (+) symbol beside the CURRENT CONTROL SET
> Now locate folder CONTROL
> There would be a (+) symbol beside the CONTROL
> Now click on the (+) symbol
> Now to locate CLASS
> Now try to locate an ALPHA NUMERIC NUMBER ends with --- 965
> Now click on the ALPHA NUMERIC NUMBER which ends with ----965
> Now look at the right side partition of the screen you can see a EDIT MENU
> Now try and locate the UPPER FILTERS OR LOWER FILTERS
> right click and DELETE THE FILTERS
> If you find both then DELETE BOTH
> Now just RESTART the laptop
> Now check in laptop whether the cd/dvd drivers are detected using the MY COMPUTER
> If it is detecting now try playing the CD/DVD
> If still NOT ABLE TO PLAY
> Reseat the CD/DVD tray
> After RESEATING the cd/dvd tray if not able to play
> Now PERFORM THE RECOVERY
Dec 07, 2010 | HP Compaq nx6110 PC Laptop
I have compaq presario 2100 i was using for 7 months now the screen is black can give me any solution
Try booting in safe mode by pressing the f8 button after the bios post choose safe mode and if you see the display just go to device manager through right click on the my computer and manage and display driver right click and uninstall and restart the comp and should be fine\
Thanks
Dec 05, 2010 | Compaq Presario 2100 Series: 1170B01-90...
Compaq Presario F700 DVD problem. Today would not
Please perform the below steps to fix this issue.
1. Check in device manager for cd drive option. in case its visible, right click on it and uninstall it and reboot the system and the corect drivers should get loaded automatically.
(to go to device manager follow the below steps:
in XP---1.On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
2.In the System Properties window click the Hardware tab.
3.In the Hardware tab click the Device Manager button.
in vista\windows 7---1.Click on the Start Orb.
2.In the Start Search box type: device manager and then press enter.)
2. Delete the upper and lower filters:
For XP
Start -> Run ->regedit - > Ok
It opens the registry editor window. navigate as per the below path
On the right side pane if you see upper or lower filter options...right click and delete them.Restart the system
For Vista
Start - > Search - > regedit - > OK
3. Check in Sysem setup/BIOS and see it the drive is getting detected. in case the drive is not getting detected over there it is a possibility that the data cable that connects the drive to the main board might be loose. if that is the case we need to go into more detailed troubleshooting. please let me know if above steps fix the issue else will provide further steps.
regards.
Jan 07, 2010 | HP Compaq Presario F500 F700 and G6000...
I have an old Presario 5000 series PC, hard disk crashed, bought a new hard disk and tried to use the Quick Restore CD's to Restore to Factory settings. Can't seem to boot up from Disc 1 of the Quick...
For boot from disk first you have to set first boot device option in BIOS.
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot menu then set first boot device as your cd/dvd rom.
then save settings then insert recovery diks in rom then check.
Then it boot from disk if your disk and cd.dvd rom works fine.
Let me know if you need more assistance.
Thanks.
Nov 05, 2009 | Compaq Presario 5000 PC Desktop
I am using HP DL380 G4 SERVER,cd rom drive is not working , thats why i connected external usb cd rom drive ,and i tried to bood 2003 server os , but failed, please help me................... if any...
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
Oct 21, 2009 | HP Compaq ProLiant DL380 G4 Server
I've lost the connection to the E: (CD-Rom) drive to my computer. What needs to be to done to get it back?
go to start>>right click on my computer>>manage>>device manager>>dvd/cd rom drives>>disable and then enable ur driver and u'll get it back
plzzz rate
Oct 15, 2009 | Computers & Internet
Cd rom does not show up in device maneger,wont
1.Check withBISO whether CDROM is there?
2.If shown in BIOS then set the boot priority to CD ROM and try with bootable disk,If booting reinstall the OS and If not then u will have to chthe CD ROM
Oct 12, 2009 | Compaq Presario Notebook
Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Logo
98 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
