Got a new washer that has button to drain water but its not draing water or doing spin cycle and keeps coming up with error its an indesit wib101 washer it wont finish any cycle at all
  • Anonymous Mar 16, 2014
    door locks but motor just clicks and wont go into cycle. red light is on and top green light is on, just clicks 3 times and does nothing.
  • 975 Answers
Check out the DRAIN MOTOR PUMP ,it could be clogged , take it out , inspect it , clean it , and try again , hope this helps AJ
Posted on May 13, 2008
Indesit iwde7125
Sounds like a control board issue
Nov 04, 2017 | Kenmore 24032\24036 Top Load Washer
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
Not spining
1st,check if you have lay down the drain hose to the ground,2nd if the drain hose is blocked.3rd,if the drain pump has problem
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
My wife restarted the rinse cycle to add fabric softener. Now the cycle timer isn't working. Washer will not drain OR spin. Everytime the timer gets to the spin cycle, it agitates instead. It is a...
Lay the drain hose down to floor level, and drain of the water into something.
Then try it on spin, if it spins o/k, then the pump or filter is probably blocked.
Hope this helps.
Jan 19, 2010 | Indesit W 123 Front Load Washer
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
I, Just got a new washing machine about 2 weeks ago it is a indesit WIB101. The Problem Is That When The washing is finished, the next day it still has 3-4 inches of water left in the bottom of the drum
i bassume the water is coming in after cycle finished. source can be two things.
water valve leaking - not probable on a new machine but to check, turn water off and see if water comes in.
if drain is plumbed into a spigot on the sink trap, when you empty the sink, some of the water will go down the drain hose. to cvure, take the drain hose up in a swan neck as high as possible
Sep 14, 2008 | Indesit Washing Machines
Indesit 123. Will not drain. Goes into spin cycle when set but no water comes out. Checked hose at front and rear.
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out....... You need good pair of grip pliers for the tubes.
And rate me pl, if the solution has worked......
Nov 26, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
