Need to install new belt on turntable Hitachi HT-L303. Any tricks to it?
Why did it stop revolving?
The driving element, be it belt or rubber puck, may have failed. It's not an unusual failure in a turntable that is several years old and rarely used.
Jan 08, 2016 | Audio Players & Recorders
Tip
Motorola L303 Manual Download
Download Motorola L303 Cordless Phone Manual
Have you misplaced your Motorola L303 Cordless Phone Owners Manual?
Would you like a digital, searchable, pdf version of the Motorola L303 Cordless Phone Users Guide?
Follow this link
(& click FREE) to download a pdf version of the Motorola L303 Cordless Phone instructions.
I hope that helps.
_______________________________________________
on May 09, 2010 | Lands Phones
Tip
Follow this link
I hope that helps.
on May 09, 2010 | Motorola Mobility L303 Cordless Phone
Im looking for cartidge for turntable hitachi HT - 354 . Where i can find . Thanks
You can use any cartridge that you want. It's just a question of getting it fixed to the arm. But many have universal fitings or adaptions. It's just a question of want you want to spend on the cartridge. Generally the more money the better the sound.
Dec 27, 2014 | Audio Players & Recorders
I've purchased motorola model L303 cordless phone do I need to program
In this ase the best will be to get in touch with our Motorola Solutions department so they can assist you with any process our setting you need on your L303. You can contact them at this link: Contact Motorola SolutionsCommunication networks services powerful...
Regards,
Gaby R.
Motorola Support.
Sep 10, 2014 | Motorola Mobility L303 Cordless Phone
Pioneer turntable is powering up but not not spinning?
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 18, 2011 | Pioneer PL-990 Turntable
Turntable turns on, but it when i press play the plate doesnt spin. i noticed it budges like a mm but definetly not working
Feb 09, 2011 | Technics SL-1200 Turntable
NEW BELT NEEDED FOR MY HT-L33
Not sure the brand but MCM electronics carries many sizes of belts!
May 24, 2010 | Audio Players & Recorders
I have an old Hitachi HT-45 turntable that I just pulled out of the closet. I plug it into my amp and I have to turn it up all the way to hear anything???
It will need a pre-amp to connect it to your newer amp. The old style turntables normally used a magnetic cartridge that older receivers / amplifiers had a special phono input (which incorporated an internal pre-amp) to connect and hear at normal volume settings. Newer receivers / amplifiers normally do not have this type of phono input, thus the need for an external pre amp device.
Dec 29, 2009 | Audio Players & Recorders
No Sound from Turntable
It definitely has to go through a preamp (a PHONO preamp that is...) something like this: http://www.phonopreamps.com/tc400pp.html
Sep 14, 2007 | Nakamichi AV-7 Receiver
138 people viewed this question
 Grubhead
Grubhead
