Question about Craftsman 4 Cycle Blower/Vac
Have 32cc 2cycle blower model # 358.797920 will not pull gas. starts when primed, will not continue running-have cleaned out hose-have not messed with adjustments. ???
steve_lima
  • 181 Answers
SOURCE: 32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Posted on Jun 29, 2009
SOURCE: craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: Carb adjustment on McCulloch 32cc?
the l is for idle and the h is for top end but thats not ur problem it sounds like ur carb is clogged there is a screen inside of the carb the fuel gets crystalized and blocks off some and sometimes all of the fuel ill bet thats the problembut u can try the adjustments first give the unit full throttle and turn the h adjustment screw in and or out till it sounds great and at full power if that dont work then do the screen in the carb
Posted on Nov 14, 2008
  • 110 Answers
SOURCE: the cord pulled out of my 32cc craftsman blower.
slow and steady, there is no shortcut for that machine, find a clean work space and start at the top. They will never win an engineering award for that one
Posted on Nov 17, 2009
2strokeguy
  • 183 Answers
SOURCE: I received an answer for a 25cc gas trimmer,
The routing of the fuel lines is the same. If you have 3 lines, that means the primer bulb is not directly mounted to the carb, rather it is connected to the carb with hoses.
Line 1. Comes from the fuel filter in the tank (smaller diameter hose) directly to the inlet port on the carb. This is the port that is opposite the diaphragm on the carb. Diaphragm is held on with 2 or 4 screws through a chrome plate. Make sure to leave enough hose so the fuel filter will fall to the lowest point of the tank when it is being used.
Line 2. Goes from the other port on the carb to the short side of the primer assembly.
Line 3. Goes from the longer port of the primer assembly and returns to the tank. Sometimes this line will have a simple coupler on the inside of the tank, but it is optional and its only function is to keep the line from slipping out. If yours does not have this coupler, just leave an inch or two of line in the tank.
*If both ports on the primer are the same length, you can test to see which is pushing air out...that's where line 3 goes.
Posted on Oct 15, 2010
I replaced gaskets and fuel lines now when i prime bulb gas runs out of carb,also need factory settings for H-L and throttle,i know i messed up somewhere?realy need my saw running,thanks
take apart your carb--sounds like your carb diaphram is not installed right the settings should be
1.5 turn out low jet
1 turn out high jet
that should get it running then some fine adjustment once its running
Sep 04, 2015 | Poulan P3314 14Inch 33cc 2Cycle Gas...
McCulloch 32cc gas blower model ct m 32 em What is the black base called that the carburetor sets on mine broke????????????????
One question mark is sufficient. Please refer to your owners/service manual for part identification.
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Oct 12, 2013 | McCulloch 30cc 2Cycle 180 MPH Gas Powered...
IN BACKPACK BLOWER USED 4 CYCLE OIL AND NOW RUNS SLOW
YOU DO NOT HAVE TO TOUCH THE CARB!!! Put the right 2cycle fuel mix in with new spark plug and run it, it will gradually pick up R.P.M's as it cleans out. once you get it running hit your primer button while holding it wide open, this will cause it to bog down and possible stall then start it again and do this half dozen times, what it is doing is pulling your fresh gas through the carb, another way is start and hold throttle wide open and work your choke open/shut back and forth several times, You do not have to clean your carb,this is simple problem to fix by doing what I said, Happy Leaf Blowing ! 2StrokeJim
Nov 11, 2011 | Garden
Hi Guru I have a 32cc Craftsman blower .. that i can keep running (only if i keep priming the bulb). I have taken apart the carb and cleaned and applied air to the lines to make sure no blockage. Any...
have you tryed pulling the fuel filter out of the tank and make sure that it is clean as well? If you can get fuel but not much I would assume it is coming from the filter.
May 29, 2011 | Garden
The cord pulled out of my 32cc craftsman blower.
Nov 16, 2009 | Craftsman Garden
Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sep 28, 2009 | Ryobi Backpack Blower 25.4cc
Jun 29, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
225 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
