Question about Sony KP-46WT510 46" Rear Projection HDTV
Green is out of line drops on edges - Sony KP-46WT510 46" Rear Projection HDTV
  • 505 Answers
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Posted on Sep 09, 2010
Veritcal yellow line on 50" sceptre tv
The edge ribbon connector may not be connecting (on the inside of the tv). Cure is foam strips between screen edge connecters and inside cover. Or, Memory chip (used to make the picture appear), may be bad. All flat panel tv's use a memory chip to make picture appear (it is digital after all). And if memory chips are bad, picture will have lines, jags etc. But it sounds like you have edge connecter problems. Place foam between inside cover and screen. TV may have been thrown around in shipment, and edge connecters came undone. They're very lightly soldered on some sets.
Dec 25, 2013 | Sceptre Televison & Video
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
How do i calibrate the accu green 3000
According to Scott's:
To adjust calibration, do the following: Adjust the micrometer setting to 6. Flip spreader over. Use your foot to squeeze the trigger against the handle. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. To adust alighment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Sep 18, 2010 | Scotts Company Scotts& Accugreeen 3000...
RCA 52 HDTV Triple iamges in red, blue and green
I had the same problem with my RCA D52W23. I change out the convergence board and the 2nd fuse the one near the flyback. After getting TV back together picture was good except white backgrounds looked washed out with greenest at the edges. I called cable company and they came out fixed my cable line with was dropping and gave me a new HDTV box which was the newest one. That fixed my problems.
Apr 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green line 2inch appeared on left hand edge next
look like you panel fail,
but you can get 2nd opinon
Jan 08, 2010 | Televison & Video
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Zebra 2844 printer green light turns Immediately orange
Clean the "cover open sensor"
location: open printer, it's at the right hand side of printer, beside the green edge guide adjust thumbwheel, in line with edge guides.
Mar 27, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Vertical red/green lines
This set has a bad digital board.and or signal board
The company is in California and is a china inport.
Digital and signal board could cost $130+
Nov 03, 2007 | Soyo Dymond DYLT032A Television
Retrace lines and poor convergence
you have bad solder connections on the convergance board solder then and get back to me k
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
