Keep saying enter c d rom disk - Computers & Internet
  • 398 Answers
When doing what? It your playing a game then you need to enter the disk. If your trying to run a program then it's likely been installed wrong and you should uninstall and reinstall.
If its Windows asking then you should run an antivirus scan and then enter your windows CD in case you've picked up a malware infection.
Posted on Sep 06, 2010
Password reset acer aspire one d250 wont boot
Try these WEB sites for removing hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Mar 14, 2013 | Computers & Internet
How do you take the write protection off of the disk drive?
As u mentioned DVD-ROM (read only memory), you can't format it.
Aug 12, 2012 | Dell Latitude D830 Laptop Computer PC...
I deleted the administrator my mistake now i cannot login to windows can I reset to the factory settings
hi, hope this helps,
1. Make sure the computer is turned off.
2. If any peripheral devices, except the optional external CD-ROM drive unit
(CE-CD05), are connected to your computer, disconnect them.
3. Turn on the computer.
4. When the message Press <F2> to enter SETUP appears, press F2. The
Setup Utility opens.
5. Insert the Product Recovery CD-ROM disk 1 into the CD-ROM drive.
6. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
7. In Boot Sequence of the Main menu, set CD-ROM Drive to the top of the list;
then, press ESC.
8. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice.
9. Read the message on the screen, and select the operating system which you
had selected for the first time you use the computer; then, press Enter.
You cannot change the operating system from the first choice.
10. Read the message on the screen, and select the way to recover your system;
then, press Enter.
11. Read the message and select Continue; then, press Enter.
12. Read the message and select Continue again; then, press Enter.
13. If you see the message asking you to insert the Product Recovery CD-ROM
disk 2, remove the disk 1 and insert the disk 2; then, press Enter.
14. If you see the message asking you to insert the Product Recovery CD-ROM
disk 3, remove the disk 2 and insert the disk 3; then, press Enter.
15. If you see the message The Operating System has been recovered
successfully, remove the Product Recovery CD-ROM disk 3. The system will
restart automatically.
16. When the message Press <F2> to enter SETUP appears, press F2. The
17. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
18. In the Exit menu, confirm Exit Saving Changes is highlighted and press
Enter twice. The system restarts.
19. Set up Windows, following the instructions on the screen. When you finish
the setup, the recovery is completed.
Jun 02, 2011 | Sharp PC UM20 PC Notebook
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
I want to reformat my computer, my question was how to first boot my cd rom to install...
Start your computer.
When you see the 'Press DEL to enter BIOS SETUP mode", press the 'DEL' key.
Change the "boot-order" to put your CD-ROM as the "first" (highest-priority) boot-device.
Save-and-exit from BIOS setup.
Insert the disk into the CD-ROM.
Your computer should boot from the disk in the CD-ROM.
Apr 07, 2010 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
My computer keep on re-booting
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jan 06, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
I HAVE COMPAQ LAPTOP AND IT WON'T START IT KEEP
If you able to login in safe mode.
Then go to start menu then type in run "chkdsk /r"
then press "y"
then restart computer then if still face same issue then you need winxp or recovery disk then repair your windows.
For boot with disk when you power up the computer press F1 or F2 or "Del" key to enter in bios then go to boot option then set first boot device as your cd or dvd rom.then save and exit.
Then put disk in rom so it boot with your disk.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Compaq Presario 700 470024-192 Notebook
HOW TO INSTALL WINDOWS 98
How to Install Windows 98 loadTOCNode(2, 'moreinformation');
  1. Insert the Windows 98 Startup disk in the floppy disk drive, and then restart your computer.
  2. When the Windows 98 Startup menu is displayed, choose the Start computer with CD-ROM support option, and then press ENTER.
  3. If CD-ROM support is provided by the generic drivers on the Startup disk, you receive one of the following messages, where X is the drive letter that is assigned to your CD-ROM drive: Drive X: = Driver MSCD001
    Drive X: = Driver OEMCD001 NOTE: If your CD-ROM drive is not available after you boot from the Windows 98 Startup disk, install the CD-ROM drivers that are included with your CD-ROM drive. For information about how to obtain and install the most current driver for your CD-ROM drive, view the documentation that is included with your device, or contact your hardware manufacturer.
  4. Insert the Windows 98 CD-ROM in the CD-ROM drive, type the following command at a command prompt, and then press ENTER X:\setup where X is the drive letter that is assigned to your CD-ROM drive.
  5. When you receive the following message, press ENTER, and then follow the instructions on the screen to complete the Setup procedure: Please wait while the Setup initializes. Setup is now going to perform a routine check on your system. To continue press Enter.
Jan 21, 2009 | Microsoft Windows 98 for PC
Toshiba laptop when turned on it freezes as windows is starting
Insert the disk in the cd rom and restart your computer......enter bios and change the boot settings...to boot from cd rom......boot of the cd and look for options such as check disk....repair disk...disk tools.....do a check disk ...or run a repair.....
Once you boot of the cd it will give you step by step details as how to repair the OS....
If you are unable to boot from cd..download a UBCD and created a boot cd this is much easier to use...
keep me posted
Cheers!
Nov 16, 2008 | Toshiba Portege 7100 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
