Question about Euro-Pro 9130 Sewing Machine
Needle won't grab thread from bobbin - Euro-Pro 9130 Sewing Machine
    Genius:
  • 1,788 Answers
Sometimes you have inserted the needle wrong, make sure that the needle faces the rear, if that is not it, try a new needle. Make sure that you have threaded the bobbin right, by your manual, and have at least a 6 inch tail, hold your top thread and move your handwheel towards you, not away from you and it will grab the thread. If any questions go to euro-pro.com
Posted on Sep 12, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 82 Answers
Make sure your bobbin is inserted correctly, and help the machine by ensuring a equal amount of thread
from top and bottom is displayed
before you insert your fabric.
Posted on Oct 05, 2010
  • 12 Answers
SOURCE: Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Posted on Jan 09, 2009
SOURCE: Needle doesnt hook bobbin thread while sewing
Our machine had the same problem, there was a piece of broken thread stuck in the upper tension spring keeping the tension spring open. removing the broken thread in the upper tension solved the problem for us
Posted on Mar 21, 2007
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Posted on Feb 18, 2009
Needle cant grab thread in bobbin
Make sure you get a new needle, put it in RIGHT. usually flat side to back. Make sure your bobbin is turning in the case CLOCKWISE
Usually it is a bent needle, or it is in wrong. Also, make sure your thread in going through the eye of the needle, and not twisted around the needle.
Mar 22, 2014 | Sewing Machines
Consew 206rb bobbin won't loop and grab needle thread
the needle thread should form the loop which is grabbed by the hook. before getting too involved with timing etc, clean bobbin area a fit a new needle
Feb 02, 2014 | Sewing Machines
My needle won't grab the bobbin thread
Please put on correct size needle. And check the tension & timings.
Jan 02, 2014 | New Home HF-106
Thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
The bobbin thread wont come up when lowering the needle
The bottom thread won't come up?
Make sure you:
-Have the top threaded and through the eye of the needle (Basics are best to check, I've missed it once or twice! lol)
-Are holding the tail of the top thread when you lower your needle and pull it back up (Hold it too tight though, and it might not grab)
-Have an inch or two of "tail" or extra thread for the needle to grab on your bobbin thread (sometimes it won't grab if there's not much there)
-Have all your lower pieces in and secure. (Mine tend to jump around if I'm not putting 'em in right)
If it's still not grabbing, I'm not sure. Sorry, hope it helps.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
My needle does not pick up the bobbin thread. I double checked that I threaded the needle correctly and the bobbin seems to be in the right position. The needle doesn't look like it's making contact with...
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Sep 07, 2010 | Euro-Pro Shark 60 - 384
Top threaded needle will not grab bobbin thread so I can begin sewing.
you might check your needle to see if it's bent
check in the bobbin area for any lint or loose threads
make sure there is a bobbin tail at least 2 to 4 inches long
hold the top thread tail ( at least 2-3 inch tail) as the needle goes down
to pick up the bobbin thread
Aug 03, 2010 | Brother XL-5130 Mechanical Sewing Machine
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Jun 17, 2008 | Kenmore 15208 Mechanical Sewing Machine
Euro-Pro 9130 Sewing Machine Logo
285 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
