Question about Sunbeam 5890 ExpressBake Bread Maker
The paddle turns very stiffly now. Don't know how to free it up. The axle that the paddle sits on has stiffened up. It will turn by hand from underneath but does not turn easily as it once did.
  • 433 Answers
Hi, The "axle" shaft fits into a sealed bearing that allows the shaft to turn smoothly. This sealed bearing is filled with a lubricant to "oil" the bearing. Over time the bearing stiffens up and the lube leaks out or gels up. Keep an eye out for any lube leaking out. Fill the pan with warm water to see if it loosens up. Do this a few times. When the bearing does fail you will need a new bread pan. Hank
Posted on Sep 08, 2010
How do i tighten the belt for the paddle?
It's a timing belt, so it isn't supposed to stretch. There is no tension adjustment that I can see. Are the 4 motor screws in place and tight? Is either the motor or the kneading paddle drive shaft turning in its drive wheel? Is the frame bent and causing the belt to walk off one of the pullies? Another problem can be that the bearing in the pan won't turn, then you'll get a loud bump as the drive mechanism tries to turn the paddle in the pan. If this happens, try to free up the paddle by hand so it turns. Then when you bake, always put the oil in the recipe in first and rotate the paddle a few turns to work the oil into the pan bearing. If the oil gets in first, it will keep the water out and the pan will work fine. I've been getting away with this approach for hundreds of loaves.
Jul 02, 2014 | Cuisinart CBK-200 Bread Maker
Why won't paddle turn??? Everything else works
Unless the bin sits correctly on the mechanism below, the paddle will not turn. It needs a very slight twist sometimes to sit it correctly. Or perhaps the paddle has some old bread still stuck in it from previous usage, pull it off (it just lifts up) and give it a thorough clean. I assume it has been working correctly?
May 28, 2014 | Kitchen Appliances - Others
Paddle is Seizing Up
Bit late in answering but have you tried a little veggie oil?
Aug 16, 2013 | Black & Decker B2300 Bread Machine
Can't remove paddle
Hi Nancy, If it were one of the metal ones coated with Teflon I would advise something different. Since it is plastic you will need to soak it again overnight with some soapy water. Tomorrow get a toothpick and begin to pick at the bread gunk in the little gap between the post and the flat edge of the post where the bread gunk collects. Once you clear enough of that out a little wiggling side to side and especially up and down should free your paddle. Fortunately B&D's usually have enough of a gap where you can do what I describe. Some paddles fit so snugly there is no gap to work with. Whatever you do don't use anything metal to try and free your paddle, you could damage the teflon coating on your pan and you never want to do that. Let me know how it goes.....
Nov 26, 2011 | Black & Decker Bread Machine
I just bought a new B6000C bread maker. I have not used it yet. The instructions say "push the paddle down firmly onto the shaft to secure in place". But, my paddles just sit loosely on the...
No, there is nothing wrong with your bread maker. The paddle is supposed to be somewhat loose so you can remove it after baking for cleaning. Don't worry your paddle and breadmaker are fine.
Jul 26, 2011 | Black & Decker B2000 Bread Maker
My paddle on the removable basket is rusted and will not move/rotate. Is there a way to loosen it up so I can use the machine again? Thanks!
Hello finkm! here is how you do it if soaking hasn't worked:I have attached a short video clip of what to do if soaking hasn't worked. The video is of a pan and paddle that was so badly stuck ( I bought it used at a second hand store) that a week of soaking did nothing to free it up. What you need to do this is a strong shoelace or piece of string about 3 ft. long, 2 hot pads places on the edges of the pan to protect your fingers,& 2 empty milk jugs filled with water. Tie one end of the string around the post the paddle sits on in the little space between the bottom of the paddle and the pan. Loop the other end of the string through the handles of the jugs short enough so that when you turn the pan upside down the jugs hang about a foot off the ground. Bend your knees a little so you in a position kind of like a short stop in baseball. Then lift and drop the pan about 4 to 6 inches so the jugs kind of POP the string. You can hear the seal of the baked on gunk breaking it seal on the first pop and then the paddle comes flying free with the second pop....Let me know if this works for you and if so give me a thumbs up on you tube and a testimonial on fixya. Glad to be of help!
Oct 25, 2010 | Welbilt Kitchen Appliances - Others
The paddle doesn't seem to have a strong enough "push" behind it
Hello, Either the blade is sticking or the belt is loose. Take the pan out and see if you can spin the paddle freely by hand. The paddle should turn nice and free. If it doesn't then the lubricated bearing the paddle rotates on is sticking. This could be due to wear. Put some warm water in the pan and let it sit. Try a few times...DO NOT put the whole pan in water...just fill it. If that's a no go the lubricated bearing is frozen and the pan needs to be replaced. If everything is fine in the pan, then the belt is loose. Belt, pulleys and motor are located in the base of the machine. Remember to unplug first before working on it.. Hank
May 25, 2010 | Toastmaster TBR15 Bread Maker
Kayak drifting to the left
These boats are very short and have a smooth hull with very little keel. Because of this they will not track well and will have a tendency to turn.
You don't say how experienced a paddler you are.
Check also that you are holding your paddle equi distant from both blades. You may be unconsciously paddling harder with your right hand if you are right handed. Most of us are one-side dominant. You may also be sitting slightly diagonally in the boat without realising it. Experiment with shifting your position. Also consider a backrest if one is not already fitted.
You can fit a skeg to the stern whichwill improve straight line tracking. Abit like a fixed rudder. Use heavy duty elastic to hold it onto the boat stern.
Aug 24, 2009 | Boating
Meade RCX 400 hand paddle does not boot up anymore.
Post this issue on the www.cloudynights.com LX Forum --
Jun 29, 2009 | Meade RCX400 12 Telescope
Spreaders how does it work?
An axle or “beater bar” is located inside the bin next to an open slot in the floor. Attached to the axle is a series of beater arms or paddles. When the axle turns, the paddles break up the material and direct it toward the opening where it is deposited evenly on the soil.
Aug 27, 2008 | Earthway 2000a Deluxe Set Up 40 Ib....
Sunbeam 5890 ExpressBake Bread Maker Logo
231 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
