Question about Hasselblad 203FE Medium Format Camera
I have a Hasselblad 203fe. The 80mm, 2.8 lens will only fire in self-timer mode-- very strange. None of the other lenses have this problem. It's almost like the lens is programmed only to fire in self-timer mode. I've tried the self-timer release method recommended in the users manual-- using the double-exposure button on the rewind crank. I've tried taking the battery out. I've tried everything I know how to do. Still, every time I mount the lens it goes into self-timer mode. Any idea what's happening here?
  • 3,083 Answers
Here is a part of a blog from Flickr:
triebensee I have a Hasselblad 203fe. - badge_pro.gif.v2 says: regarding the self timer, you can also use it without setting the shutter release to "T" if you use a locking cable release.
Posted 6 months ago. ( permalink )
And another:
D?¡? badge_pro.gif.v2 says: alex ......There is a little metal notch on the left that reads V X M as well,... have no idea what this is for...
this is for self timer and flash sync.
to use self timer you also need to use the switch on the camera (bottom right if looking from the top), set to 'T' position.
Originally posted 6 months ago. ( permalink )
D?¡? edited this topic 6 months ago.
I'm thinking there is a setting issue (sorry about the text, it changes when pasting stuff).
I couldn't find any information about your specific problem, per se, only references to settings, so hope this helps, and thanks for using FixYa.
Posted on Sep 06, 2010
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
I have 400 & 640mm Novoflex lenses latest type I wish to use on Hasselblad 201f (focalplane shutter). First, will these lenses cover the 6X6cm format? Second, what kind of adapter do I need and...
Yes they will. You need a Novoflex HAPRO adapter which can be ordered from your camera store. You may also need a new focus tube if your lens is set up for a 35mm camera as the flange focal length for 35mm is different then for your camera.
May 15, 2011 | Novoflex Hasselblad Lens Adapter Ring Lens...
Currently have sigma 28-80mm 1:3.5-5.6 and 100-300mm 1:4.5-6.7 lenses both 55mm that I use with my Pentax MZ-50. I would like to purchase a DSLR camera and rather than waste the lenses I already own would...
before buying ask the sigma salesman or dealer about it, i know only for nikon camera- it's lenses are compatible for all camera, digital or film base slr cameras.
Feb 12, 2011 | Sigma 28-80mm Mini Zoom Macro Lens
I pressed the shutter release button while attaching the lens to the body. Now my Hasselblad is jammed. The diaphram is closed, the shutter crank knob is turned about halfway, and the lens is stuck half...
On my Hasselblad 501 CM, I have never encountered this problem. As expensive as these cameras are, and delicate, I wouldn't chance it. I would contact the Hasselbad company and ask them to fix it for you.
http://www.hasselbladusa.com/service--support/technical-support/contact.aspx
I would try the above link to contact hasselblad's tech support if I were you.
Good luck on this.
Dec 25, 2010 | Hasselblad 501CM Medium Format Camera
I have a Hasselblad 500C/M camera and can't get the lens on.
http://www.butkus.org/chinon/hasselblad.htm
Get the manual. They are picky, it might require the shutter to be wound or something like that.
Jul 01, 2009 | Planar Normal 80mm f/2.8 CFE Lense
1,2,4 hasselblad cft* 80mm speeds runs like 1/30
Those speeds tend to hang up from lack of use. You can try exercising them by cycling through the speeds, but it will most likely need service. The lubrication on the gear train has probably dried up, it is a common problem since those speeds aren't normally used.
Sep 28, 2008 | Hasselblad Cameras
Lens not stopping down
sometime it may happen, put the camera body without lens put it on the speed of b see when you klick the camera the shutter will go up and also mirror then the body is ok , put the lens sapratley you will see one small part is over the mount when you rotate it the lens appurture is opened and close u can put the f2.8 the ere is closure of appurture when you move the knob like wise u change the app and vise versa
Feb 09, 2007 | Hasselblad 80mm f/2.8 CFE Lens
Unsharpness
if you can acquire sharp image with your 80mm, but not the 50mm and 120mmmm, there is no problem with your camera body, i.e. lens-flange to film plane. but how come you can not manage to get a sharp spot anywhere from the full turn of focusing rings with your 50mm and 120mm, unless the lens units inside these 2 lenses shifted. i doubt this happened to both lenses simultaneously?
if you are sure that your lenses have problem, send them for focusing test, since they are good and expensive lenses.
pc-cook
Sep 14, 2006 | Hasselblad 503CW Medium Format Camera
Hasselblad 203FE Medium Format Camera Logo
Top Hasselblad Photography Experts
Tony
Are you a Hasselblad Photography Expert? Answer questions, earn points and help others
