Question about Kenmore Elite Oasis 6808 Electric Dryer
I have an elite kenmore dryer and it doesnt dry and it smells like burnned
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 10, 2010
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I bought this kenmore elite gas dryer in 2003. It has a burning smell inside the dryer. What can cause this?
check the belt on the drum for wear , if it smells like rubber burning,
Jun 08, 2011 | Dryers
My dryer smells like burnned its an elite kenmore oasis and it doesnt dry very good
heatman101
Sep 06, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Burning chemical smell coming from the gas dryer
You first thought was probably the correct one...the fumes from the new paint may take a few days to disspate enough not to react with the heat of the dryer...I would give it a few dyas to clear before looking any further...
heatman101
May 28, 2010 | Kenmore Elite HE4 Electric Dryer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE 4 IS NOT DRYING AND GIVING BURING SMELL
ensure the lint screen is clean, check your discharge vent hose for blockage or kinks. You may need to move the dryer out from the wall to thoroughly inspect the vent hose. while the vent hose is removed from the dryer, start the dryer momentarily to ensure the is sufficient air flow exiting the unit.
Feb 08, 2009 | Kenmore Elite HE4 Electric Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE4 electric dryer
If this is a Kenmore Elite front loader, taking the back off isn't going to tell you much. The heating element is inside the dryer under the drum on the right hand side. More than likely you have an accumulation of lint on the heating element housing and its beginning to smolder. Running the dryer on low will not change the fact that you have lint in close proximity to a glowing element. It will still burn. Here is a link you can look at that gives you some advice on dryers:
http://www.fixya.com/support/r385301-thorough_dryer_advice
You will need to unplug the dryer and remove the lower panel under the door to gain access to the heating circuits. If you have lint backing up into the dryer, you need to investigate why. If its been a while since you've inspected your dryer ventilation ducting, it would probably be a good idea to do so. Everything is in the link I provided for you. I hope this helps.
PS Conitued running of a dryer in this condition can cause the heating circuits to overheat and fail and/or cause a fire.
Jul 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis 6808 Electric Dryer Logo
107 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
