Question about Hitachi 50UX58B 50" Rear Projection Television
Hitachi 50ux57b the color was messed up (green and blue ghosting) so i tried to fix it but it has analog settings and i can't figure out how to get them back to factory. I Can't get my satilite remote to operate the TV with any of the codes I can find.
  • thomasEsims Jun 01, 2008
    I have red and blue ghosting across the top of my screen I spoke with a repair tech he said their is either miss adjusted lense or a cracked mirror but I have neither problem I noticed the bubble on the red tube has indention unlike the others I saw that the ICs could be the problem but sadly am not sure what a IC is I however can solder very well so with a little direction I believe I can fix it with your guidence oh guru of hitachi world
  • 4,234 Answers
The green and blue ghosting is a convergence problem that is either bad connections at the convergence ICs or defective ICs. If you can solder, try resoldering the ICs. If that fails to resolve the problem, replace them. These ICs are large black ICs attached to a heatsink. They should be marked STKxxx.
Keep us posted.
Dan
Posted on May 13, 2008
50" hitachi 10 years old has blue and green colors
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 12, 2010 | Hitachi 50UX57B 50" Rear Projection...
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Set will not power on
Replace both of your STK ICs STK392-110s use 120s or 150s Mats has them 1-800-628-1118
ck Low ohm resistors in same circuit 1.2ohms -3.9ohms
May 29, 2010 | Hitachi 50UX57B 50" Rear Projection...
Colors on the screen are messed up with ghost HITACHI
Its not clear what kind of tv you have but it appears to be older rear projection tv with three picture tube. This problem does occur due to the convergence board going bad. Needs professional help to repair unless you know a lot about soldering ICs. Check out at www.fixurtvs.com for more answers on this problem, repairs and costs.
Feb 26, 2010 | Televison & Video
Tv duplicate image
your guns are off and need to be adjusted. your 3 guns (red, green and blue) are off and that would explain the funny colors and shadows. Have a tv tech come out and have a look, they can fix it for a reasonable price.
Oct 20, 2008 | Televison & Video
Hitachi Mode; 53UDX10B
http://serviceman.site88.net/index.htm
Jul 06, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50ux57b
check menus for default settings, or check the manufacturers website. Even calling the manufacturer is a good idea just to help you get through the menus
Apr 19, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 50UX57B 50 inch Rear Projection smearing...
try this
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
