Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
My linksys spa2101 is locked, i dont have the password, what can i do
  • 4,281 Answers
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Sep 06, 2010
My LINKSYS as for password, it is locked
Press and hold the reset button of the Linksys router using a pointed object (like a paper clip or pen) for 30 seconds.
The reset button is located in the back of the Linksys router closest to an Ethernet port.
The button is recessed to protect you from accidentally resetting the modem.
Unplug the Linksys router while pressing the reset button.
Shut down your computer for one minute.
Plug the Linksys router back into the wall outlet.
Reboot your computer.
Open your web browser to access a website.
Type the below in the address bar if you want to reset your password:
http://192.168.1.1
A prompt from the site will request a user name and password.
The user name stays blank, or, in some models, is "admin".
Navigate to the security tab. Input your new password to protect unauthorized access to your router
hope this helps
Sep 17, 2012 | Linksys E3000-rm 802.11a/b/g/n 2.4/5ghz...
My LINKSYS ask for password, it is locked
http://192.168.1.1
hope this helps
I 'm trying to get my wifi..it wont work, i called comcast and they said to reset it and the password. i dont remember any login or password...help
The default password for Linksys routers is admin the user is left blank
some routers have slightly different than this user id admin and password also admin the last possibility is user id admin and password is just password
good luck!
Sep 16, 2011 | Linksys Wireless-G WRT54G Router
I am trying to get my smartphone to use my wifi network but says locked or secured with wep. i dont know how to find that. i am using linksys wireless. help please
You need to log on to Linksys router to find the password or you can use with no password by resetting the router.
To get on to Linksys router connect the router to your computer with ethernet cable using one of the LAN ports on the router. Open a web browser on your computer and type 192.168.1.1. That will ask you a user ID and password. Leave the user id blank and type admin in password section. Once you are on router open page click on wireless and then security which will take you to router wireless password. Type that password on your smartphone to get internet access on smart phone! Good luck!!
Sep 03, 2011 | Linksys Computers & Internet
I WANT TO CHANGE MY PASS WORD ON MY LINKSYS E2500
access the ipadd of your linksys then thats the time you can change your password. if you dont know the password then its time you reset your router and reconfigure it again.
Aug 25, 2011 | Linksys By Cisco E2500 DualBand WirelessN...
I want to lock my router but dont have the wizard and dont know how to do it
By lock I assume you mean secure it.
To do so do the following -Plug an Ethernet cable from your computer into one of the ports on the back (not the one labeld WAN) -Verify your default gateway. Open a command prompt by click "start" > run or "windows" button, and type cmd -type ipconfig and remeber the default gateway should be like 192.168.0.1 -open a web browser and enter that number into the address bar -you will be prompted for a user and password. (should be either admin, no password or admin/admin) -Go to the wireless > wireless security tab Select your security Choose WPA2 with PSK - create a strong password alphanumeric - Save and you are now "locked" You will then need to go into Network Connections/Network and Sharing and enter the password you created.
Jul 09, 2011 | Linksys Wireless-G WRT54G Router
Locked out of wireless router .
On the rear of the router is a recessed reset button. You'll need something like a pen point or a straightened paperclip to press it. Turn off the router (pull out the AC adapter plug), the plug it back in while pressing the reset button. After the lights on the router quit blinking, let go of the button. This will reset the router to factory settings. When you go to //192.168.1.1 and are prompted for username and password, the username is blank and the password is admin. (It's possible the username may be admin and the password is password. This was in some versions of the router.) Then you can set your router up again the way you want.
May 18, 2009 | Linksys Wireless-G WRT54G Router
Wireless Router Reset
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 24, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Password of linksys spa 2102
The Linksys comes with web admin access disabled.
To enable it, pick up phone, dial **** then 723646# , when asked for password, dial 78778839# , when asked for value dial 1# then dial 1 to save.
Then, go to »192.168.0.1/admin/voice/advanced , enter user and password.
If you did a factory reset, you will need to call Linksys technical support.
Nov 09, 2007 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
2,202 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
