Question about Masterbuilt 20070106 Electric Smoker
I'm getting power to my smoker but the heating element is not getting hot. What can I do?
  • 11,896 Answers
Get a voltmeter or multi-tester, test power to the element. If there is power, then heating element is bad. If not power to the element, then temp sensor or control board may be bad.
Posted on Sep 06, 2010
  • mike Dec 06, 2011
    i get 120 at bolth ends of element so there is power going threw it sounds like my new is bad also
SOURCE: My electric smokers heating element
I just had the same issue and almost had a Thanksgiving disaster! Try unplugging the connection between the smoker and control pad. mine looked like it was on, i could set the temp, time and get a reading of temp, but it must not have been sending the 'heat' command. also, bass pro has thios on sale tomorrow for 129
Posted on Nov 27, 2008
  • 6 Answers
SOURCE: I have a little chief 9800 top load smoker and
The #4 Little Chief element is 7 inches and more importantly is 250 watts, this is the correct wattage for ALL Little Chief Smokers newer than about 15 - 20 years old.
The #5 Little Chief element is 8.5 inches and is also 250W but is for newer models before 2006.
Look at www.smokehouseproducts.com for clarification & best fit.
For very, very old models (20+) there is a ceramic disk (175W) that heats the chip pan and is hard to find and expensive, a person would be better off finding a new one on sale at the big box boys store
Posted on Jul 31, 2009
  • 491 Answers
SOURCE: I need to replace the heating element. How do I
LOOK FOR AN ELETRICAL AND PLUMING OUTLET IN THE LOCAL AREA AND BRING THE PART WITH YOU WHEN YOU GO FOR THE PART .
Posted on Nov 05, 2009
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
SOURCE: My heating element is not working. How can I get a replacement.
I experienced the same problem. My heating element was not working. After a Continuity Test, the Heating Coil was dead and needs replacement. I asked Masterbuilt if any heating coil replacement parts were available. They said "no", but they could offer a discounted sale on a new Smoker for about $175.00. I am still looking. A local appliance dealer said the internet was the most likely place to find one. After looking on the internet, I can't seem to find one yet. If you know of any, please let me know. Call (616) 772-1332 and ask for Bob. Thanks
Posted on Jul 30, 2010
Why after five minutes or so of becoming hot does the grill trip my power
When you say power I am guessing you mean the ground fault switch. Struggled with that myself until recently. There are a lot of posts out there of people with this problem with a variety of smokers. Try plugging into an outlet not protected by a ground fault outlet. If the smoker works that way (mine did) I would suggest you replace the electric heating element. For $30 bucks or so this fixed my smoker. Found my part on appliancefactoryparts.com. My smoke is a Masterbuilt brand. Putting the new element in was pretty easy but a bit messy. Look for a video on YouTube for your smoker.
Good luck and happy smoking.
May 07, 2016 | Grilling
30" Masterbilt smoker won't get over 60 degrees. I
I am having the same problems with mine. I have rebuilt the connection, three times.
I am going to pull the element out and replace it with a single-burner heating element like the Proctor-Silex 34101. That will be plenty of heat for the smoking I do.
Jan 31, 2011 | Masterbuilt Electric 30inch Smokehouse ...
My bradley smoker has no power going to the light or heat element in the smoke tower.all wires and fuse look good. could it be the heat element or rheostat switch?
With power off remove bottom plate check heat element for continuity.Rheostat is mounted on controll board sometimes meat juices flow out door and into controll board shorting it out like mine.Saw web site where someone used pid controll in place of rehostat control board.
Jan 16, 2011 | Bradley BT1S1 Smoker
The digital control panel is not working. the heating element is ok. the heating element is ok but it won't heat up
Use a hair dryer or a hot wet rag on the internal thermostat. The smoke will not start if the internal temp is below 40F. Once you warm up the internal thermostat, it will start right up.
Dec 18, 2010 | Masterbuilt 20070106 Electric Smoker
Jul 10, 2010 | Masterbuilt 20070106 Electric Smoker
Heating Element Failure
Mike in Alaska
PSU313@yahoo.com
Apr 03, 2010 | Masterbuilt 20070106 Electric Smoker
The heating element does not operate -doesn't heat
How true: I love this smoker but until the heating element doesn't work. I am on my 3rd one now. Each have had the heating element go out. Luckily the 1st 2 smokers I took back to where I purchased them and they "Cabalas" gave me a new one "NO questions asked". Now I have this 3rd smoker. Guess what! Not heating again. I decided to take this thing apart myself and investigate the problem. Since the unit is all sealed I need a Drill, dremal cutting tool to open up the backside to get at the heating element and wiring. What I found was that the CONNECTOR to the heating element was BURNED up. All wiring was fine! I believe MasterBuilt is not putting in a high enough temp connector and also the connector looks to me of dissimilar metal which will cause metal breakdown when heated. I then went to Ace Hardware and found some High temp connectors and replaced the originals. All working now!
My friend has the same smoker with the same problem ... He called Masterbuilt and got the song and dance and how much it would cost to fix - so went out and purchased a Different Brand. Knowing that I had fixed my smoker I ask him if I could take his apart .... Well and behold ..... It had the same CONNECTOR problem. I wish I had my 1st 2 smokers back to check those out also. But my theory is that they also had the same problem.
Here is 1 more problem I have seen with this Smoker ... I store my smoker on my deck all seasons (covered up when not in use). During the winter when it is cold out my smoker control panel will not come on. It always works when it was warm out. So what I have found is if I take the control panel off and bring it inside to warm up .... Then reinstall it all works fine! My theory is that the control panel has a liquid crystal that is freezing causing it not to work.
Sep 11, 2009 | Masterbuilt 20070106 Electric Smoker
My electric smokers heating element does not get hot-after only about 20 uses-Any suggestions-The manufacturer said they would need to send me a new box for $199-Seems rediculus this cant be fixed?
Oct 30, 2008 | Masterbuilt ESQ30B Smoker
Brinkman electric smoker
The pan for the wood chips is a round shallow (1/2 or so high) pan, about 8 inches in diameter, that sits right on top of the heating element. The element doesn't get too terribly hot, so you could probably substitute a foil pie plate or even a double wrapped package of aluminum foil with some holes punched in the top. When you see the smoke - its time for the meat!
Good eats!
Pat
Jun 29, 2008 | Brinkmann Smoke' n Grill Electric Double...
Electric water smoker low heat
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Dec 04, 2006 | Char-Broil Electric H2O Smoker
Masterbuilt 20070106 Electric Smoker Logo
942 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
