Question about Sony Handycam DCR-SR40 Camcorder
I have used my Sony Handycam DCR-SR40 and the battery went dead. I then charged the battery several times and still won't turn on. I even attach the camcorder to the Sony base and connect it to the computer and it still won't work. Please help! Do I need a new battery? What's wrong with it?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 29 Answers
SONY DCR-SR40 battery Specs:
  • Cell Type : LI-ION
  • Volts : 7.4V
  • Capacity : 900mAh
  • Average Run Time :2-4 hours(minimum)
  • Color : Black
  • Dimension : 33.6*32*45.6mm
  • Net Weight : 75.8g
  • compatible model: sony np-fh100, sony np-fh30, sony np-fh40, sony np-fh50, sony np-fh60, sony np-fh70,
    Buy cheap SONY DCR-SR40 battery:
    (UK)
    http://www.global-battery.co.uk/camcorder-batteries/sony-dcr-sr40.htm
    (US)
    http://www.sales-battery.com/camcorder-batteries/sony-dcr-sr40.htm
  • Posted on Sep 29, 2010
      Genius:
    • 1,812 Answers
    This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
    My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
    If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
    Posted on Sep 06, 2010
    Can I get the video off of my Sony Handycam DCR-40 without the docking station? It broke, so I want to know if I can connect it to the computer directly? I'm not willing to lose the video we've taken, so...
    I bought my DCR-SR40 used (just camera) and I have the same problem. Downloaded the instruction manual from sony and discovered the only way to connect to a computer is through the
    Sony Camcorder Docking Station
    #DCRA-C162
    and a Special USB Cable!
    Jun 02, 2010 | Sony Handycam DCR-SR40 Camcorder
    I have a Sony Handycam DCR-SR40. I can playback
    The new laptop does not have the codecs installed . Install any software that came along with the camera. Or download latest codecs and install
    Apr 26, 2010 | Sony Handycam DCR-SR40 Camcorder
    Sony DCR-SR290 camcoder- turns off abruptly
    ribbon cable located in the rotating lcd is cut. thats why the shut down its grounding it self out. needs to be replaced. real pain though, cable is serpintined around the part that rotates. sony does flat rate for prob. about 250 US
    Jun 01, 2009 | Sony Handycam DCR-SR40 Camcorder
    ImageMixer software "could not find Handycam." DCR-SR40
    After camera is on dock and usb is plugged in, turn on the camera. You can open the door to see the status of the connection as an option. This should do it. If the camera is off, nothing will happen when you run the imagemixer software
    Jan 16, 2009 | Sony Handycam DCR-SR40 Camcorder
    Will not power on with battery
    the battery is dead or that power circut has a problem, but make sure you have a goo battery
    Oct 16, 2008 | Sony Handycam DCR-SR40 Camcorder
    Cable needed to connect SNY DCR-SR40 Hndycm N DCRA-C162 Handycam Station to computer
    There are 2 cables,
    1. A-V Connecting Cable P/N 1-831-553-11
    2. USB Cable P/N 1-829-579-41
    attached with Handycam Station DCRA-C162. Hope this info is helpful to you.
    Aug 12, 2008 | Sony Handycam DCR-SR40 Camcorder
    Sony Handycam DCR-HC30 2004 model
    Your unit is a 2004 model. If it has never been used since then the battery is probably no good and will need replaced. Batteries discharge 20% on a monthly basis just sitting on the shelf so yours went dead a long time ago. Then if they are left in that state (dead) they sulfate which means that sulfur oxides transfer to the plates and form an insulating surface. At that point all the charging in the world is not going to bring it back. All you can do is get another one. They are available at most stores which sell electronics. Get a new battery and charge it per the instructions and try using it again. This should solve your problem. Good luck.
    Jun 13, 2006 | Sony Handycam DCR-HC30E Mini DV Digital...
    Sony Handycam  DCR-SR40 Camcorder Logo
    281 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
