Question about Frigidaire Dishwashers
I have a Frigidaire Gallery Model Number FGHD2433KW1. It is about 3 weeks old. It has now done two washs with the water going in because there is water draining out and soap is still in the dishwasher and dishes are not clean. It seems like there is no water coming from the sprayers. Please help. Thanks in advance, Irma Self
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
  • 131 Answers
SOURCE: Frigidaire dishwasher dirty & sticks in cycle
First, check the holes on the upper spray arm. They should be clear of food and debris.
Next, There's a check valve (ball) built into the motor unit. Either it's stuck, or the motor isn't pausing at the appropriate time to switch from bottom spray to top spray. You can test the check valve by opening the door momentarily while it's running. The spray noise inside should sound distinctly different. Pausing longer will switch back to the lower spray arm.
If the check valve works, you'll need a new timer.
Posted on Mar 10, 2008
larryyb
  • 291 Answers
SOURCE: soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
Posted on Nov 25, 2008
  • 677 Answers
SOURCE: my viking dishwasher does not rinse the soap scum off the dishes
Its not soap, its actually calcium from hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Posted on Aug 12, 2009
SOURCE: My Frigidaire dishwasher is leaving soap, a lot of
I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
Posted on Sep 16, 2009
Why is my old Frigidaire gallery washing machine filling with water and won't stop?
bad water control solenoid
bad diaphragm in the inlet control
water level switch faulty
Oct 10, 2016 | Frigidaire Washing Machines
How many cubic ft. in a 2001 Frigidaire Galley model #FWT647GHS washing machine
Hello friend, that's a great question!
I understand you would like to know the cubic footage of your Frigidaire washer. Based off the model number you have provided your washer appears to be a 4.4 cubic feet washer. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Washing Machines
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
What is the capacity of the Frigidaire Gallery model FWT449GFS0? It is approximately 13 years old.
The capacity of the Fridigaire FWT449GFS0 is 2.7 cubic feet. I got this info from calling the Frigidaire toll-free help line. It is NOT part of the model number!
Jun 14, 2012 | Frigidaire Washing Machines
Frigidaire top load washer approx 6yrs old water keeps running into it won't stop and won't go into cycle water won't stop even by cuting the power had to shut off the valve
The problem is your water inlet valve has failed. It is stuck in an open position. Part # AP3267279 at www.appliancehelponline.com
cost is $37.87 easy to replace. Remove top cover to acess.
Mar 18, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Jan 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
It doesn't drain after the wash cycle
can you hear the pump humming? you may have jammed pump or a blocked pump.
Oct 31, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dishwashers Logo
317 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
