Question about Indesit Washing Machines
Water pump on my Indesit NBR5000WD has gone out. Can it be replaced? Steve Ward
  • Indesit Master
  • 3,463 Answers
It is possible to replace the water pomp on most makes of washer including your model.
Posted on Sep 06, 2010
My 1wd7145k (uk) has stopped working mid cycle, I have restarted and it fills with water ok but does not start to spin but continues to count down on the program timer. the motor does not spin and I
May be the rubber belt is gone open the screws behind the washing machine and check if the belt is worn out or cut replace by buying the belt of the same code number printed on the belt
Nov 15, 2014 | Indesit Washing Machines
Water not pumping out
is the pump working if it is is switch gone on the pump
Jan 31, 2013 | Indesit IS70C Electric Dryer
My indesit d63 dishwasher (which has worked brilliantly for years) has recently been leaking water onto the floor. When I open it at this point, it is full of water. I have read the articles here and think...
Sounds like your shaft seals have gone.
This usually takes more labor, special tools, and parts than the unit is worth. Unless it is a family heirloom or something, suggest replace it with a new machine.
Jan 16, 2018 | Indesit 24 in. D63 Free-standing...
The washing machine will not drain after the wash cycle. I have checked theout flow pipe but its not blocked and if I disconnect it the water will run out into a bucket. Any ideas? steve davies
there may be something small like a tooth pick bobby pin or something else in the drain pump.if you check the drain pump and you do not find anything in there then you may need to replace the drain pump
Mar 05, 2011 | Indesit W 123 Front Load Washer
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
IDL 700 Dishwasher
it sounds like you are going into flood mode. tip the unit 45 degrees to the side and see if you are getting loads of water pouring out. if so you have a leak and need to check components in the base.
Mar 24, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit washer dryer
check heater element first, thats a common fault on these machines, loose connection or open circuit, after that check the pump for same open circuit
the rotating of the timer knob indicates a fault, maybe even a setting fault, to try and reset set to off, turn off and back on again, till light flashes, then turn off again and start again
if you do not know how to test for open circuit then the job is not for you, sorry
Oct 14, 2007 | Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Machine does not move back and forward
it proberly the carbon brushes in the moter get someone who knows what their doing to replace them easy job to do.cost £10
Jun 07, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
