Question about Cameras
How do i import pictures from my samsung memoir camera? is there a difference between the charging cable and a usb flash cable that connects from cell phone to computer?
  • bmc3369 Sep 06, 2010
    the solution to the problem was that the picture(s) have to be saved to the phone's memory card then they can be imported into your computer
    Genius:
  • 1,044 Answers
The charging cable is different from USB flash cable. You can go through the booklet provided with the phone and it will show the diagrams of the cable and their part no. The charging cable has the two pin plug on one end whereas the USB flash drive cable will have USB heads on both ends, one which goes in the phone and the other which goes in computerMake sure that you down load the software which comes in the CD (which came with your phone) on your computer.
Posted on Sep 06, 2010
  • Adarsh Saroj Sep 07, 2010
    Sir,
    The pictures in Smsung cameras are generally stored in the memory card. You do not have to save as it is done by the camera automatically. If you want to download them to your computer you can do it by two methods. One , I have already described o you i.e. by USB cable. The other is by removing the memory card from the camera and then inserting it in the card reader slot if your computer has that facility.
Cannot import pictures from camera to computer
If your computer is having poor earthing the currant leakage spoils the IC inside the USB port of camera. try in another laptop and confirm the same.
May be we can supply the manuals for servicing and spares
Sep 29, 2013 | Sony Cyber-Shot DSC-H1 Digital Camera
Galaxy Tab OTG Connection
SAMSUNG GALAXY TAB USB OTG CONNECTION CARD READER
With the Galaxy TAB OTG Connection, you can easily download the photos from a digital camera or from a USB Flash disk straight to your Galaxy Tab and share them with your family and friends.
The reader has 3 Connector each with a different interface:
1. USB Port can connect to the digital camera, USB mouse, USB Flash Disk, etc. It also support external keyboards.
2. Using the SD(HC), MS card reader imports photos from your camera straight on to your Tab.
3. Using the TF, M2 card reader, photos from your camera will be directly transferred straight on to your Tab.
Your Galaxy Tab will automatically open the photos after you make a connection and you can then choose the pictures you wany to import.
Jul 11, 2013 | Android Apps
How to import picture from Samsung camera PL120?
Transferring files by connecting the camera
as a removable disk
Connect the camera to your computer as a removable disk.
1 In Shooting or Playback mode, press [m].
2 Select Settings - PC Software - Off.
3 Turn off the camera.
4 Connect the camera to your computer with the USB
cable.
Transferring files with Intelli-studio
Intelli-studio will start automatically when you connect the camera
to your computer with the USB cable.
The battery will charge while the camera is connected to a computer with the
USB cable.
2 Select Settings - PC Software - On.
cable.
5 Turn on the camera.
• The computer recognizes the camera automatically and
Intelli-studio launches automatically.
6 Select a destination folder on your computer, and then
select Yes.
• New files stored on the camera will automatically transfer to
the selected folder.
• If your camera has no new files, the pop-up window for saving
new files will not appear.
Rate my answer if this helped you.
Sep 13, 2011 | Cameras
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
How to get Photos From memory card to computer
  1. Hi
  2. Plug your Samsung mobile phone's USB flash cable into the phone and into the computer's 2.0 USB port outlet. When the computer detects a USB connection, a notification screen will appear in the lower right corner of the screen, above the task bar. The phone's software driver will be automatically installed to your computer's hard drive.
  1. Import your pictures to your computer. Click on "Import Pictures" when the "AutoPlay" dialog window pops up. Close the "AutoPlay" window to configure the import settings.
  2. Choose a gallery title for the pictures you are importing. When the blank data form appears in the bottom right corner of the screen, type a name for your gallery in the data form. Click on the "Import" button to begin the downloading process.
  3. Remove the Samsung USB flash cable from the computer and then from the mobile phone. Click on the "Start" menu icon, then select the "Pictures" tab folder. Your newly imported pictures should be stored in this folder. Please Rate this solution. Regards.
Nov 12, 2010 | Samsung Cell Phones
My usb cable for the Kodak EasyShare z710 is not uploading any of my pictures. I do not see the dialog box to even import the pics. Is it because I used my usb cable on a Samsung Cable that need charging,...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Oct 12, 2010 | Kodak EasyShare Z710 Digital Camera
When I turn on camera flash opens and then closes right away.
  1. If any accessory devices (memory card, lens, USB cable, camera or printer dock, etc.) are connected to your camera, disconnect them.
  2. If your camera is on, turn it off.IMPORTANT: Verify that the battery/batteries are installed correctly.
  3. Install a new or fully charged battery/batteries into your camera.
  4. Turn on your camera.
  5. Set the flash to iconfillflash.gif.
  6. Take a picture.
Aug 23, 2010 | Kodak EASYSHARE M1063 Digital Camera
On start-up, Samsung S860 beeps 3 times then turns itself off
first off,never use rechargable batteries in this camera or most digital cameras for that matter.2 use only lithium batteries,enegizer preffered.,also yes you can view all your pictures when connecting the usb,meke sure you turn the power on,and highlight the word computer,push ok.you should be fine.good luck .i hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
Unable to download pics on my Samsung L100
have you check if you are using the usb cable or the av cable. the camera will not show anything on the screen if you are using the av cable and connect the camera to your computer.
Jan 11, 2009 | Samsung L100 Digital Camera
Cameras Logo
141 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
