SOURCE: working on farmall super a tractor distributer had
Remove valve cover,bring #1 cylinder top dead center,make sure both push rods are loose,put you dist in and were ever your rotor is pointed that will be your number one wire.then you will have to adjust you timing when started by ear,I hope this helps you
SOURCE: 1942 farmall tractor stalls after 10 - 15 minutes of bushhogging.
I think you still have a fuel issue like your float level is to low,I hope this helps you
SOURCE: NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
