Question about LG Prada KE850 Cellular Phone
Prada phone HI there, What do you do if you dial a number that has a multiple choice. eg press 1 to speak to an operator, 2 to pay a bill etc.... How do you access the number pad while on a call.?
You know the little speaker botton below the volume pres that and the number pad will show on the screen
Posted on May 13, 2008
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
Push numbers whilst talking on phone
1. FYI, when your call is dailed through successfully - please pay attention as there are two instructions on the screen. It tells you to press which button for dailing and which to press to unlock the screen.
2. To answer your question: On the left hand side of the phone, there are 3 buttons. Press the button at the bottom below the volume up & down buttons. The dailing screen should come up.
This button is also used as a shortcut for changing profiles quickly in the main screen.
Jan 22, 2010 | LG Prada KE850 Cellular Phone
How do I programme numbers into the KX-T7730
hi kim
if u mean how to store a phone number on a Flexible button, her is the way:
1. Press Program button to be on Programming mode.
2. Press the desired Flexible button you wish to assign as a One-Touch Dialing button.
3. Dial 2.
3. Enter the desired number (extension number, phone number, etc.).
4. Press STORE.
Ali
Aug 25, 2009 | Panasonic KX-T7730 Corded Phone
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
LG Prada security code
This is a small tutorial on how to hard reset the lg prada on request for forgotten security code. Turn the prada on without a simcard and wait for the insert sim screen. On the touch screen hit call, after enter this code 2945#*#. and you will see a menu pop up headed "Engineering menu". scroll down to factory reset hit that and wait for it to reboot.
Best Regards
Dec 25, 2008 | LG Prada KE850 Cellular Phone
STORING NUMBERS KX-T7750
Store a number in the phone memory
  • Press “Program” key
  • Press “*”
  • Press “ #”
  • Press “1234”
  • Press for number“001” for name “002”
  • Press “SP-Phone” key
  • Press “SP-Phone” key (de là if faut choisir le speed # on pressant sur cette clé)
  • Press “9”
  • Enter phone number (as dialed normally)
May 14, 2008 | Panasonic KX-T7730 Corded Phone
Cannot activate dial pad
Do a hard Reboot, Turn your phone off and wait 10 secs then turn it back on it should be fine.
May 03, 2008 | LG Prada KE850 Cellular Phone
Deleting Voicemail
Press the hard button which you normally use for switching profiles this will enable the keypad which you can then press the relevant number to delete your voice mail
Nov 20, 2007 | LG Prada KE850 Cellular Phone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
LG Prada KE850 Cellular Phone Logo
59 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
