My externa 5635 laptop-when I plug in power cod-Latop show its POWER LED.when I want to start it. Its not start. become totally POWER OFF. when eject BATTERY, then become as it is.
  • 388 Answers
Make sure your plug is connected firmly to the powerbrick and that there is no dirt in the connectors of the battery. Also try a different adaptor.
Posted on Sep 06, 2010
I have an acer extensa 5635 with a full battery that wont turn on.
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Apr 21, 2013 | Acer Extensa 5635 Notebook LXEEA03007
My hp laptop don't turn on even the charger is
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 02, 2013 | Computers & Internet
My Notebook all of sudden doesn't power on.
I find that many times when a laptop won't power on either on batty or plugged in, the thing to try is to unplug it, then taske the battery out for about a minute and then put the battery back in and try again.
Dec 13, 2012 | Toshiba Satellite L755-s5248 15.6" Laptop...
I am unable to start my HP pavilion dz6700 laptop..it turns on and in a sec it switches off. Battery of laptop is dead and even though i connect to externa power source it doesn't start
Unfortunately there's a problem with the motherboard of the laptop, you need to replace it. One of the circuits is grounded or is totally dead to accept and release power for the unit to turn on.
Hope this helps.
Jun 13, 2011 | HP Computers & Internet
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Dell Latitude D610 Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Inspiron 1420 dell says plugged in not charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Feb 22, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
HP altec lansing Pavillon DV 6700 not powering
I am sorry to say that this is likely to be motherboard damage. The only other possibility is the the Power jack on the laptop itself is loose or shorted.
Either way.. You need a qualified repair.
The safe bet is a new motherboard.
sincerely,
Sagacious1
Aug 07, 2009 | Computers & Internet
Laptop cannot see externa drive
do you get a LED blinking ? is there power on the drive? Is the Activity LED blinking as well?
Dec 23, 2007 | Western Digital imicro IM35ST320SI 3.5 IDE...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
