Question about Kensington SlimBlade Trackball Bluetooth Laser Laptop Mouse
My kensington slimblade wireless keyboard types a "p" infront of every key I type. if I hit the "k" button, then it returns "kp"p plplplipke tphisphp plkjpjpj also, backspace doesn't seem to work
  • 25 more comments
  • droserose Sep 06, 2010
    I'll be damned. that worked! would never have guessed it.
    well, that worked for about 5 minutes and now the problem is back...but I already paid my $6!
    so any ideas what to try next? I used the air and it worked for about 5 minutes, but now the problem is back.
  • Anonymous Mar 11, 2014
    my brother HL-4040CN is holding all my print requests in queue
    how to remove the back bumper of a Daewoo Lanos 2001
    l need to get instruction manual for this model gym to set it up . having trouble finding it
    Where and how do i check the gearbox oil on a 1998 VW Polo Classic manual and what should i use gearbox oil or transmission oil?
    Car makes whining noise on start up. Afer a few minutes it gets quieter.
    Gas tank went low, dirt got into fuel pump. Need to knock pump to move dirt for it to run. Is it Possible to Back Wash fuel pump? Any suggestions ?
    replaced bulb but turn signal still not working on 2007 caravan
    tracfone customer service - Iwaas sent a replacement Alcatel phone but have been unable to get human assistance to transfer my number and MINUTES.
    I'm driving along and it jerks and picks up again
    HOW TO REPLACE THE DOCTOR BLADE ON MY OKI 5150
    magenta spots on left side of printed pages
    torque specs for 97 dodge stratus intake
    My 1989 325i BMW Starts and idles fine and smooth, runs at lower speed (like 25mph)with no issue and it doesn't seem to sputter or backfire. However, when it reaches about 2000 RPMs it seems like it is losing fuel pressure and it cuts out dropping the RPM and repeats
    Need Manual for keystone autoload 8 mm projector
    water in radiator cap gettimg very hot and water not staying cool
    the coffee switches off after it is done brewing. How do I fix it
    Ignition coil 4 cylinder
    I slammed my hatchback down on an object and it wouldn't shut. Moved the object and now the hatch wont open. What do I do to get it opened??
    do valve stem seal burn oil
    1989 jeep cherokee loose stering calum
    both sides blinking erratically
  • Anonymous Mar 12, 2014
    it will only play one cd I've downloaded onto it. none of the others. just says 'couldn't play track you requested'.
    DVI wired to HDMI smart TV. Desk top and wall paper shows but no icons or anything. Just shows wall paper. Likely a PC setting needs changed. Which one?
    canon ix6560
    when the printer is printing then it shows the operator error.how to manage this problem?
    President:
  • 4,070 Answers
Hi! As a first course of action, I strongly suggest that you blow compressed air on the keyboard. If the keyboard is dusty it tends to fail and blowin compressed air can resolve this. Hope this helps and thank you for using FixYa!
Posted on Sep 06, 2010
  • dj_relly999
    dj_relly999 Sep 06, 2010
    You have a nice day now!
  • dj_relly999
    dj_relly999 Sep 07, 2010
    Hello again. Looks like that the keyboard itself is worn out. It's a wear and tear thing that replacement will surely be recommended.
I can not uninstall the bloody thing
You cannot uninstall a keyboard program like you would any other program, because the keyboard is in use, the way to do it is, power the computer down, then unplug the USB adaptor, key board and mouse, you must replace the keyboard with a wired one before you can restart the computer, you then go to control panel add remove program and uninstall the software. Good luck.
Dec 20, 2009 | Kensington SlimBlade Wireless Keyboard and...
Kensington mac os x driver doesn't work
Try Step A
Unplugging it and re plugging it back in
Or if you have another mouse do step A then move the curser with the mouse and now the trackball will work
Frustrating Isn't it !
Nov 07, 2009 | Kensington Expert Mouse Trackball
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
How I connect my KeyBoard with PC kensington Model:64355 FCC id:H8grfkb21 M Amjad KhanPur Pakistan
Go to this site:
http://us.kensington.com/html/3846.html
Almost at the bottom of the site you will find your keayboard,"Kensington Comfort Type Wireless Desktop Software", and you will find drivers for it, and you will find instructions how to install it
Good luck
Dec 10, 2008 | Kensington Comfort Type Wireless Optical...
Kensington key board
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Hope this helps. Bud
Aug 31, 2008 | Computers & Internet
Apple key no longer working
The Kensington keyboard is being recognised as a PC-style keyboard, and the software has swapped the action of Apple (Command) and Alt (Option). Go to System Preferences > Keyboard and Mouse, and set the Modifier keys correctly in the Keyboard panel.
macs2u
Jun 16, 2008 | Kensington Comfort Type Wireless Optical...
Mouse not responding
Are the batteries good?
Try
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
May 24, 2008 | Kensington Comfort Type Wireless Optical...
Kensington SlimBlade Trackball Bluetooth Laser Laptop Mouse Logo
88 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
