Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Not defrosting I have a GE Model GSS201EPHWW every 2 weeks I have to remove the inside back panel to expose a frozed solid evaporator coil to defrost it. this unit does not have a timer I believe it is controlled from the circuit board in the back.How do I go about troubleshooting the defrost element and thermostat to determine if i need a new panel or other part?
  • 1 more comment
  • Anonymous Oct 02, 2008
    not defrosting
  • Jessicavan00 Dec 30, 2008
    help what can I do to fix this
  • aprilnhhh May 11, 2010
    And if the defrost heater is not black then what should I look at next?
    Genius:
  • 1,073 Answers
First thing is to check the defrost heater if it looks black it is bad the part number for the heater is wr51x10053
i have replaced a ton of these
Posted on May 13, 2008
  • Wookie85 Dec 17, 2010
    I changed the heater last year, what is the next step in troubleshooting i chk volt at the leads and im getting 11vac.
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
The freezer saection is freezing up causing the refridgerator to get warm, I defrost and this works for 2 weeks. What would you look for?
remove the rear panel inside the freezer in there will be the evaporator coil,if its covered in a layer of solid ice then defrost it with a hand held hair dryer,then with the power shut off to the unit unplug the defrost heater underneath the coil and test for continuity,if this checks good then test the defrost thermostat on the top of the evaporator coil,you will need to put this on a piece of ice or cool it to below to make the contacts touch otherwise it will show open(bad) if this shows good(closed),then check for 120 volts a.c. on this circuit when is in defrost mode
Nov 19, 2010 | Magic Chef CTF2125 Top Freezer...
I own a GE Refrigerator model#GBS18HBRAWW Bottom
if you mean the freezer froze up and you replaced the defrost thermostat in the freezer,then you need to check the continuity of the defrost heater assembly located on or under the evaporator coil for continuity(completed circuit) with at least one of the leads to it disconnected,if this shows good,then you need a new defrost timer,be it an adaptive or timer type,last but not least it could be a bad connection and this circuit could be losing power and needs to be checked,but this is very rare
Jun 06, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
GE side/side was not cooling. Removed back cover and vacumed dust from fan cage. Freezer temperature is now 33.3 degrees 2 hours later. Whats the problem?
First i want you to look into back of the freezer and see if you have a layer of frost or snow clinging the rear panel. If yes these models have more problems with the defrost heater and defrost thermostat than usual meaning you are possibly not defrosting. Unplug and let's examine the rear of freezer by removing contents and manually defrosting by removing the rear panel and exposing the evaporator coil. Let me hear f you find different like clicking noise or the compressor getting so hot you cannot hold had there. Let me Know, Sea Breeze
Feb 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
After unplugging and defrosting my ge tfx20nw it
Good day,
The defrost system has failed. It is made up of a timer, defrost thermostat, and defrost heaters.
The timer is located behind the light guard in the fridge compartment.
The heaters and defrost thermostat are located in the freezer compartment, behind the back wall.
To test,
1. With the machine running, in the fridge compartment, pull off the thermostat knob, and then unclip the light guard.
The timer is behind the panel exposed, but has a hole to insert a small screw driver to advance the timer.
Turn the timer clockwise until the machine shuts off. Wait 45 plus minutes. If the machine turns itself back on the timer is good.
If not, remove the panel, and install a new timer.
2. If the timer is O.K. then the problems are in the panel on the rear of the freezer compartment.
Unplug the machine, and remove the rear panel. Allow it to defrost.
There are two quartz radiant heaters, one located on the bottom of the evaporator coil, and one half way up. There is also a defrost thermostat clipped to the top of the evaporator. It is a round disk about an inch in diameter.
Purchase and replace all 3. You may need wire nuts to splice wires together so purchase them as well, when getting the other parts.
Go slow, the heaters are easily damaged or broken if handled roughly.
Dec 15, 2009 | GE Refrigerators
Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Oct 18, 2009 | GE Refrigerators
Frezzer is icing up and frig is getting warm . we tried to defrost by shutting down. we did this twice model #msd2957de
Hi, If you are having frost build up, you will need to remove the rear panel inside the freezer. Unplug the refrigerator. You will need to test the bi-metal switch that is located on top of the evaporator coil and it needs to be cold when testing it. If the bi-metal switch shows an open circuit, it will need to be replaced. If the switch shows a closed circuit, test the defrost heater the same way.
If both parts show they are ok, you will need to replace the defrost control which is located inside the fresh food section in the control panel.
If it is solid ice that you find after removing the freezer panel. the drain under the evaporator coil is plugged and will need cleaned out.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Freezer frosts up and stops cooling after approximately 2 weeks GSS201EPHWW
AUTO DEFROST IS BAD REMOVE FREEZER BACK PANEL CHECK HEATER CONTINUITY WITH REFR. UNPLUGGGED IF HEATER BAD ORDER HEATER KIT FOR YOUR MODEL
Jun 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dripping water inside even though freezer is working perfectly. Is there a plugged drain? Is it suppose to drain to a pan on the bottom and then evaporate? I tried looking for a drain pipe in the back...
yes they all have a drain pan. when unit goes through defrost your ending up with water on the inside of unit. remove rear panel in freezer to expose evaporator. hole is under evaporator. see if it is froze over
Jun 22, 2009 | Refrigerators
The entire backwall of the unit is solid ice. 2
OK first defrost the refrigerator. Unplug and remove the back panel covering the evaporator and lets look at the defrost element and defrost thermostat. If they are OK we may need to have a look at mother board mounted on back of fridg. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | GE Profile PDS22SCRL Stainless Steel...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
366 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
