Question about Samsung SyncMaster 931B 19" LCD Monitor
I had a power surge and now my samsung monitor blinks rapidly at the power button and wont power up is there a fuse on it
  • 11,361 Answers
There is a main AC fuse, but since you are getting indicator light, it means the main AC fuse is good. I would look inside for burnt parts, bad caps, etc first. Post the picture of the board will help.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Sep 07, 2010
LG 60PN6500 plasma tv power surged. has no picture and i think no sound. tv wont turn on but stand by light illuminates but then shuts off. in a cycle fashion. cant find my multi-meter to check fuses
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 20, 2017 | LG Televison & Video
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
USING MANUAL SETTINGS
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
5. Press SET BUTTON (#5). The SOUND EFFECT INDICATORS of
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
Mar 02, 2016 | Jensen Interactive AM/FM Talking Dual...
Our power went out for a brief moment and now the Samsung LN32A450 LCD TV we have isn't working and there is only a blinking red light on the bottom. Any suggestions?
Try unplugging and plugging it back in. Was there lightning, and was it attached to a surge protector?
Try pressing the power button repeatedly or even slapping the back of the tv (try googling this).
Oct 20, 2010 | Samsung LN32A450 LCD Monitor
The power light is red and blinking rapidly, screen blank
is it plugged into wall or a surge? may make a difference. Some screens require certain amount of KV and some surge protectors have less KV than needed to run some things. good luck
Oct 01, 2009 | ViewSonic VX900 19" LCD Monitor
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
Sep 07, 2009 | Samsung SyncMaster 760vTFT Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Screen is blank.
Could have blown some capacitors inside the monitor.
I just fixed one today that had no power, the blue ring around the power button didn't even light up when plugged in.
I open it and found 3 bulgingcapacitors on the power/inverter board.
They were all 25V 470uF rated capacitors.
Went to radioshack and found 2 35V 470uf, got them at $1.29 each, then I found 1 50V 470uF out of a dc car power adapter for an ipod, it was as close as I could find.
Replaced the 3 broken/bulging ones with the new/salvaged ones, put it back together, plugged it in and the blue light came on when I pushed the power button.
Plugged it in to my laptop with vga cable, and it works great.
Oct 24, 2008 | Samsung SyncMaster 932B LCD Monitor
Monitor dosn't atart
Check SDL,SCL Path and It's related parts(Neck board PCB 2 MICOM)
check Output Voltages of SMPS
And also check dry points.
Oct 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Samsung SyncMaster 931B 19" LCD Monitor Logo
181 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
