Question about Kenmore Washing Machines
OOPS! I posted this as a solution by mistake. Sorry people. I have a Kenmore Model 110. 22632100. We were washing clothes and after agitation the washer did not drain or spin. I took all the clothes and water out and turned the knob to the spin area and it does not spin. If I put the knob to the start position or rinse position it will begin to put the water in.
  • 50 Answers
Check the pump for blockages. First unplug and drain the machine by hand as much as possible.You will have to tilt the machine to access the bottom of it. The pump will have an incoming water pipe from the drum, and an outgoing pipe to the drain. These pipes are usually fixed with spring clips which you press to release (may need a plier here). Remove the pipe that comes to the pump from the drum.Check for items blocking the pump via the opening for the pipe. You will probably find a sock or some other item blocking the pipe. Remove and re-fit the pipe and spring clip. It should work now.
Posted on Sep 06, 2010
I have a Kenmore wash model #110.200220 and it makes a noise when it agitates only
it could be the noise of clothes bottons or zip. Generally it's normal for a washing machine to make noise when agitating
Jun 15, 2014 | Kenmore Washing Machines
Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
My Kenmore agitates while trying to spin??
sorry the repair is a new gearcase appx 230.00 plus labor in your area or buy a new washer ,,,,,
Aug 29, 2009 | Kenmore 24032\24036 Top Load Washer
Rubber coupling is getting shreddedprevents agitator from working
no it's not a recurring problem. Q. Can you spin the agitator freely in both directions when the machine is off? Please post the entire model number 110 is just the first 3 didits.
Apr 11, 2009 | Washing Machines
Washer will not spin by itself unless i take all the clothes out
POST THE MODEL NUMBER FOR FURTHER ASSISSTANCE. I THINK YOU MEAN THE TRANSMISSION, RIGHT?
Dirt and Lint on all my clothes
You can go to www.shop.washermd.com and there is a downloadable tutorial for removing the agitator. You also may need to replace the agitator dogs. Dave
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine Kenmore 3.2 cu ft Super capacity plus top loader
fabi, if Im reading you right the machine fills with water and just sits there. Can you hear the motor running when it should be agitating? If so you might have a broken coupler. If the machine is quiet and just sits there, it could be the pressure switch. The first picture shows the pressure switch with the rubber hose and purple wire going to it (far left). There is no model number posted but this is a top loading Kenmore, should be close. Take the rubber tubing off the switch and blow into the switch with another piece of tubing. Does it start agitating? If so, there's your problem. If you do hear the motor running and it's not agitating it may be the motor coupler. If you need more assist...email me at catriver1@gmail.com Catriver..post back.
Feb 05, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Trouble with constant spin
If your Kenmore is agitating and spinning at the same time then you have a gearcase problem. The gearcase is warranteed for 5 years part only. The labor would run around 133.00 Your model is a direct drive washer and changing out the gearcase is not that bad of a job. Part number for the gearcase is 3360630. Catriver..post back.
Jul 31, 2006 | Kenmore 22622 Top Load Washer
Washing Machines Logo
119 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
