FixYa.com
Tags:
IBM ThinkPad T30 2366 PC Notebook
T30 2366 8GA After removing AC Adaptor battery...
posted by vasforu on May 13, 2008
I have an IBM thinkpad T30 and when the laptop is NOT plugged
into the wall using the AC adaptor,
windows battery icon shows the laptop as still being on AC power.
Sometimes continuesly Display getting Dim an Bright means switching to battery and power i feeling.
Help me. It would be most appreciated. Thanks.
I did the follwing....
1.When working the system unplugged AC adaptor. it showing still Charging and working on AC.
2.Formated and installed fresh windows XP with Sp2
2.Battery backup is getting already 2.4hrs So i think no battery problem
3.I didn't upgraded the bios and Embedded controller..
4.Fully dissasambled and cleaned IO Board as well as mainboard..
Still problem Existing...
Help Me plz..........
Comment by vasforu, posted on May 29, 2008
sorry.....There is no switch ......
What i found is ADP3806 is the charging IC in T30.. Near by that one Diode is burned and the code written on that is 25.
I removed that but i don't know the value of that diode means voltage specifications .Anybody know the what is the value?
Means code is 25 ...Value=???
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 26, 2008
FixYa! (100)
shaggyrat
Rank:Wiz Wiz
Rating: 82%, 439 votes
there is a switch in the plug end to the back of your comp its like a little swinging door that when you unplug out of back of comp this switch engages battery now if you unplug just from wall its going to see these 2 things the doors not shut but i have to keep working so it sets aside the plug still recognizing it of course but running off the battery trying to still find out why the powers not there but the plug is still plugged in and it will continually search until it reaches its falt point of dead battery
its like a battery backup for your system it gets unplug but wants to know where the power is
now in reference to the little swinging door i call it its a power over relay in your comp for some reason its not closing properly to allow battery to run by self
this is usually just a switch that needs adjusted in the motherboard configuration
Rating Locked! (?) vasforu has rated this solution as FixYa!
Can you Help with these PC Laptops problems?
PC Laptops
New ASUS G50vm-x1 from Best Buy
I bought this laptop yesterday,... Answer This...
PC Laptops
Power-on Password
I trying to see were to send in... Answer This...
PC Laptops
acer aspire 4720z audio driver...
can't load the audio driver on... Answer This...
PC Laptops
my CD drive is not working
My CD drive used to work - put... Answer This...
PC Laptops
there is a problem with my...
when im going to type b button... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
