Question about Texas Instruments TI-83 Plus Calculator
Won't turn on and I put new batteries in, first thing
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please append a comment to this post and we'll go on from there.
Posted on Sep 06, 2010
  • rygiel Sep 07, 2010
    Thank you for this idea. Unfortunately no luck. I also tried the solution of removing one of the batteries and then removing all the batteries including the backup. This did not work either. Any other ideas I would appreciate. Thanks again.
  • kakima Sep 07, 2010
    Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries. Does the calculator turn on now (you may have to adjust the contrast as described originally)?
Put in new battery and it won't turn on
Hello, Hard to tell with info given, Try new battery to determine if it is battery related or a camera failure, Batteries are cheaper than camera repairs.
Hope this helps, Russell
Dec 10, 2012 | Kodak EasyShare Z612 Digital Camera
Sanyo vpc-s1213 12 megapixel, 3x optical zoom lens stuck out, won't turn on
Mine did the same thing after I put in a new sd card. Finally after trying everything else, took out the sd card and it worked.
Apr 10, 2012 | Cameras
I have tooken the battery out for 10 minutes like this thing has said and its still not charging nor turning on? What else do I need to do???
Sometimes you just need a new battery. If you took the battery out and gently put the battery back in and it still won't turn on. Take it to the store you bought it and get them to look at it.
Kris R.
Feb 24, 2012 | AT&T Cell Phones
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 25, 2011 | Polaroid Cameras
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
My Lumix DMC-LX5 camera won't turn on
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
My student's ti nspire won't turn on. They have the 84 face plate on it.
Put in new batteries and try again.
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 12, 2011 | Texas Instruments TI-Nspire Graphic...
99 windstar van, won't turn over,won't start, headlights won't turn off,
baterr ywas dead changed it-new battery worked-discharged once air turned on-put in 2nd bateer yseems fimne as long as you don't turn on the air-if you do there is a clicking inside radioconsole and discharges battery
Jun 17, 2011 | 1999 Ford Windstar
Problem when starting up sony cybershot W55.
Your problem is mainly like above.
If you want to check the other troubleshootings please download the user manual of Sony Cyber-Shot DSC-W55
Feb 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Texas Instruments TI-83 Plus Calculator Logo
54 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
