Question about HP LaserJet P3005dn Printer
I have install catridge problem with my hp laserjet p3005dn
2 Suggested Answers
  • 87 Answers
SOURCE: How do I stop my HP LaserJet P3005dn Printer to st...
The most common place for these to squeak is the fuser, usually a bushing that holds the lower (pressure) roller has failed and the shaft is grinding against the frame of the fuser. Grinding will usually occur shortly after. You need to remove the fuser and examine where the lower roller's shaft comes out to the gear for bushing wear. Then you can replace the fuser with a rebuilt, or replace the right and left bushings if you want to tear down the fuser. Another squeak can come from a toner having bad bushings allowing the drum to rub the plastic housing of the toner. Yet another could be the bushings holding the final roller shaft for the exit bin, requires removal of the top,
Service manual can be downloaded at feedroller.com - down the left nav bar at the bottom is a link to manuals.
Posted on Jun 25, 2010
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
HP Laserjet P3005dn printer makes a loud grinding sound while printing. Prints OK, but users are annoyed by the sound
Replace the fuser and the fuser drive gear. When you order the fuser make sure that they include the gear.
Nov 22, 2010 | HP LaserJet P3005dn Printer
HP LaserJet 3005dn drivers free download
You need to download the printer drivers from the Compaq/HP WEB support/download page. Make sure you select your model printer and the XP or Vista Windows version of the drivers you require and install them.
Click on this link to download the drivers: -
www.hp.com/#Support
Apr 03, 2010 | HP LaserJet P3005dn Printer
Hello,In HP P3005dn printer unable to print double side print from tray 2
1. check to see the that the tray is installed correctly
and is functional. (See Use
information pages)
Configure the device driver to
recognize the installed tray. (See
the device driver online Help.)
Turn the device off and then on.
Verify that you are using the correct
optional tray for the device.
Mar 25, 2010 | HP LaserJet P3005dn Printer
My printer hp laserjet p3005dn will not let me print from tray 2 every time i try and print it goes to try 1
You may not have configured the HP for two trays.
Open Printers and Faxes - right click on the HP printer and click on Properties - click Device Settings tab - Installable Options, in Number of Input Trays enter "2" then click OK.
When you print you will be able to select the tray1 or 2 to print.
Sep 01, 2009 | HP Laser Jet Printer P3005dn
Doesn't read new black cartridge
HP Laserjet 3055 - New Black Catridge.
Solution :
01. First remove all catridges from the Printer.
02. Clean the printer with Cleaning liquid in the catridge seating cover.
03. Re install the catridges gently and assure that it is properly seated.
04. Always use only genuine HP original catridges which will give longer life for the printer.
05. Refilled or Reinked ribbons will cause lot of damages to the printer.
06. Better to have the regular servicing for this printer.
If the problem continues, please call local authorized HP Printer service engineer.
Jul 17, 2009 | HP LaserJet 3055 All-In-One Printer
Installing driver
Hi jjcr_7 - What is the make/model of your printer? (There are several different variations of this printer model):
» HP LaserJet P3005 Printer
» HP LaserJet P3005d Printer
» HP LaserJet P3005dn Printer
» HP LaserJet P3005n Printer
» HP LaserJet P3005x Printer
If you are using Microsoft Windows XP - Please visit the link below and download the PCL6 Univerisal Printer Driver. After you install the printer using the add new printer feature and select the option to browse (find the folder you downloaded the driver to) and install the printer. You can also install just the software which you can use if necessary or you want the HP software on the machine for user friendly help in the event of an error or support from HP to diagnose your problems.
(Copy and paste this link into your browser)
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1846089&prodTypeId=18972&prodSeriesId=1846088&swLang=8&taskId=135&swEnvOID=228
If you have already installed the software - uninstall the printer first then uninstall the software - delete the folder it creates in the Program files folder for HP. (Do this before installing just the printer with the driver)
Some times when you download the software from the websites they don't always install the correct printer or driver type. Often just downloading the driver from the page will be the best option.
Jul 08, 2008 | HP LaserJet P3005n Printer
What is MemTest failure replace DIMM0 on an HP Laserjet P3005dn?
It says to replace the DIMM, but you really need to replace the formatter. We run into this all the time with this model of printer.
Feb 13, 2008 | HP LaserJet P3005dn Printer
HP LaserJet P3005dn Printer Logo
Seeker5211
Seeker5211
