Question about Genica 4Channel Standalone Network DVR Home Digital Wired Surveillance Kit w35 LCD 4 Infrared camera
I have a Gen IV Technology Standalone 4CH DVR. Every time the recording starts or I attempt to view the playback, the system reboots and it says "HDD Error". How can I fix this? Thanks.
Have an error message on screen sayng NO HDD???
The system does give this message when the logic board can't access the Hard Disk.
Can be anything, from a complete over filled HD till a defect controller or just a corrupted first sector. Check what the user manual says about initialise the hard disk. If that won't help, consult a tech close to you. Btw. after an initialise or format you will have lost everything you recorded till now. So if something important is on the disk, ask a tech to get out the drive and recover the important stuff. This could cost you.
Mar 30, 2015 | GW Security Professional 4 Channel 1t Hdd...
Pls help me step by step how to online viewing from my cctv
You need to provide us with more info. Your dvr broadcasts on an iPhone address with a port number. Both of these are needed. Then the bbrand of router you have is also needed
Nov 24, 2014 | ECHO1USA 4ch H.264 Standalone Dvr 204e...
Can i connect to my laptop with that cctv view where i can see all camera on same screen?
you will need a multiplexer to connect all your cameras into and out to laptop on the front of the multiplexer you can use the buttons to see one or all the cameras you have installed.
May 24, 2014 | Astak Wireless 2.4ghz Night Vision Color...
My H.264 Network DVR resolutions are not compatible with mt Monitor. How do I reset the resolutions manually ?
You may be lucky because the battery acid may not have gone beyond the contacts in the battery chamber: open battery chamber and clean out especially at the bottom of the chamber and blow out any loose stuff when you finished cleaning ( use pencil erazor or something similar , but do not use sand paper or anything that will damage chrome plating of the contacts ; you do not want corrosion at later stage ).
Sep 16, 2012 | GW Security Professional 4 Channel 1t Hdd...
Dish 622 freezes up
You have a hard drive failure and will need the unit replaced. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Intermittantly freezes on playback. Toshiba rs-tx20 dvr
shut down tv/dig box/dvd. unplug and then leave a little (cuppa time)
replug .then start up dig box then tv then dvd.sounds like in need of "reboot"
Sep 01, 2009 | Toshiba RS-TX20 DVD Recorder
Playback issues
Assuming that there is no loss of signal detected by the system and an 015 message being presented onscreen and that you have adequate record time available than your hardrive in the receiver is almost gone. You will need to have the receiver replaced. When this is done you will lose all recorded programs. The Dish Vip series of receivers offer a USB port that can be used to either expand the recording capacity of a DVR receiver with an external hardrive or if you get a non dvr unit e.g. 211, 222 you can eliminate the DVR fee each month by turning the option on for the external hardrive at a one time fee of 39.99. This will save you money by not paying the dvr fee anymore and alleviate having your recordings being lost if the receiver ever goes bad. I hope this assists you and thanks for using Fix Ya.
Feb 06, 2009 | DISH Network DVR-625 DTV Receiver /...
Not able to play back on the DVR
The ssc duel records with a time signature that allows you to go back to a specific time to view the information on the harddrive. on the front of the dvr there are three buttons and the large round multi button. If you have the unit with vhs backup, then you just press the center small button on the front pannel and you'll get the menu that either allows you to select a time group to watch, or put in the time you want the playback to start. after you start the playback, then you can control the playback with the controls on the large multi function button. If your trying to play back the VHS tape, GOOD LUCK!!!!.....If you have the newer model without the vhs backup...then you have to press the stop button on the large multi function button...andthen press the center small button and then the other small button to the right...then you should be at the menu to play back the video either by selected time/date..or by half hour increments....good luck!!!
Dec 10, 2008 | Samsung SSC DVR Digital Video Recorder...
Genica 4Channel Standalone Network DVR Home Digital Wired Surveillance Kit w35 LCD 4 Infrared camera Logo
315 people viewed this question
Top Genica Home Security Experts
Lawrence Oravetz
Are you a Genica Home Security Expert? Answer questions, earn points and help others
