Question about Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television
Good afternoon, my Mitsubishi model 42413 turns on, then immediately back off back again. After testing with the menu and device buttons, I get a flashing 2 - 3 code. What does that mean & how do I go about fixing it?
  • 2 more comments
  • buzzardnest Sep 06, 2010
    I'm game to testing it out if you can give me detailed information please.
    Yes, a copy of the service manual would help & if that doesn't work, or is too involved for me, I will need to take it in for service. Thank you for your help.
    I was able to download the files and they will help a lot. My son is going to check it out for me. Thank you for all your help today. At the very least, we'll have the knowledge to call around to find a good deal if we can't fix it ourselves. Thanks again!
  • bill7177
    bill7177 Oct 21, 2013
    Do you know the error code 2-4 means?the model is wt-42313
  • 10,594 Answers
Error 2-3 means deflection loss
TV detects deflection circuit is not working thus show 2-3 error code
Possible causes are loss of main power supply that goes to deflection circuit and/or horizontal output transistor got shorted out and causing shut down.
Let me know if you are handy person and can test parts in circuit board of tv to provide you more technical info about problem or local tv repair shop will help you to fix it.
Thanks.
Posted on Sep 06, 2010
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics Sep 06, 2010
    Will service manual help you?
    It has schematics of tv to test power supply output voltage info
    I have service manual and can provide you copy
    OK, click HERE and download both files, its complete service manual of WT-42413 Mitsubishi tv
    If both files does not appear, put tv model number WT-42413 in search box on same page to get the result.
    Hope this will help you to fix your tv
    Thanks.
    Thanks and good luck :)
  • Damon Wilson Oct 30, 2010
    im having the same issue... i can test anything that needs to be tested, can you please email me some instructions to test parts.... jdmiam4901@yahoo.com
    thanks
    Damon
    i have the same issue, and the ability to test can you email me more info on how to fix this and test the issue... thanks
    jdmiam4901 at yahoo.com
    Damon
    Shahid Electronics Oct 30, 2010
    You can download service manual copy form given link and follow troubleshooting as per instructions in service manual. Thanks.
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
When turned on mitsubishi WT-42413, it turns off itself within a second. any help?
Check you -24and + 24 on power supply and you green fuses if open fuse replace fuse and the stk394-250 good luck
Jan 16, 2011 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi Model WS 55511 was made in March of 2003. I turn it on and it goes right back off again. On the front of this TV I only have an Enter button, a menu button. an A/V Reset Button and a Device...
Device is the same as input--try the self check, when power light goes off press and hold it and menu at same time for five seconds and release.
Device means input.
Let me know error code and I will help you more than anyone else.
SD TECH
Sep 18, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Good afternoon, my Mitsubishi model 42413 turns on, then immediately back off back again. After testing with the menu and device buttons, I get a flashing 2 - 2 code indicating a fuse is blown. I opened...
2,2 means one of the pico fuses (see attached photo) that protects the convergence circuit is blown---This set uses 2 of the STK-394-250 convergence chips---you need to locate and replace the fuse and the chips---do not just replace fuse---it went for a reason, if just fuse replaced it will blow again and likely do other damage.
If this or the photo helped, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Tv won't stay
It sounds like the convergence went out. STK 394-250 and some pico fuses. Check that the error code is 2.2 before you replace any parts.
To check the error code simply hold down the menu and device buttons for 5 sec and count the flashes inbetween pauses. Goodluck.
Jul 05, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi rear projection HD1080p tv model # ws-48311
press in the menu and input/device buttons both in together on the TV and hold in for 6 seconds to see if the led will blink a two digit error code then let me know what the code was.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wt-42413 Power problem
Okay try to distinguish if the three blinks is 1 pause then 2 blinks or 2blinks pause 1 blink. As the set will only blink a two digit code 12 meaning no error detected and 21 meaning the set is hutdown due to xray protection.
May 13, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi wt-42413
No you have to push the buttons on the set that say menu and the button that says Input or device both in together for 8 seconds to initiate the self diagnosis feature.
Apr 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Only Blue Screen
1. Suspect the Signal PCB part # 930B923002
Aug 20, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television Logo
200 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
