Question about Siemens Gigaset-DE380-IP IP Phone
Can't connect to the web configurator of my DE380 IP R, any solution. Same network, phone has an IP and i could manage to configure it to connect to my sip server thrue the phone menu..
    New Friend:
I am having the same problem. If you ever get a solution please share it with me
Posted on Oct 29, 2014
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
What is the default ip address for hp 2510-24 j9019B switch ?
Switches don't have an address, think of them more like a traffic intersection with 24 roads.
When you plug a device into the switch, that device gets assigned an ip address.
For example:
  1. Phone line comes in to your house and stops at your modem, your modem is plugged into the switch. The modem picks up the private network address 192.168.0.0
  2. Your computer is plugged into the switch. It picks up ip 192.168.0.1
  3. Your friends computer is plugged into the switch. It picks up ip 192.168.0.2
This carries on until you have filled all the sockets on the switch.
The ip's here are only on your personal network, to find what your external ip (your modem -> internet) is just type 'whats my ip' in the google search and it will show you your public ip address.
Nov 24, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' sales@internetvoipphone.co.uk ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
Turn on shuts off blue screen B8000028
The steps to resolve this issue on a product that you want to set up with a wireless connection and on a product that you want to set up with a wired, or Ethernet, connection differ slightly. Depending on the connection type you want to set up, select one of the following methods, and then follow the steps provided to resolve the issue.Method one: Resolve the error on a product that uses a wireless connectionStep one: Print a network configuration page
  1. Disconnect the power cord from the back of the product.
  2. Remove the phone or Internet cable that is connected to the back of the wireless router. Do not reconnect this cable until instructed to do so.
  3. Reconnect the power cord to the back of the product. If the product does not turn on automatically, press the On button (c00636182.gif ) to turn the product on.
  4. Make sure that the blue Wireless light is on. If the Wireless light is not on, press theWireless button on the front panel of the product to turn wireless on.
  5. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  6. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  7. Press the Setup button (c01726396.gif ) on the product control panel, select Network , and then select Wireless Setup Wizard . Follow the instructions in the wizard to complete the configuration.
  8. When the Wireless Setup Wizard is complete, press and hold the Cancel button for several seconds. The network configuration page prints.
  1. Make sure that the computer is connected to the same router that the product is connected to.
  2. On the network configuration page that you printed in 'Step one: Print a network configuration page,' look in the General Information section. Make a note of the following information.
    • IP Address
    • Subnet Mask
    • Default Gateway
    note.pngNOTE:Each of these addresses is in the IP address format. For example, 192.168.1.100 is an IP address. Make sure that you note the numbers and the dots exactly as they appear on the network configuration page.
  3. Open a Web browser, such as Internet Explorer or Mozilla Firefox, on your computer.
  4. Type the product IP address in the address bar of the Web browser, and then pressEnter . The Embedded Web Server (EWS) page for the product opens.
  5. On the EWS page, click the Networking tab.
  6. In the left pane of the Networking screen, select Wireless (802.11) , and then select theIPv4 Configuration tab in the right pane.
  7. Select Manual IP .
  8. In the IP Address text box, type an IP address that is within the range of 192.168.1.10 to 192.168.1.60. For example, the IP address 192.168.1.25 is correct, but 192.168.1.61 is incorrect.
  9. In the Subnet Mask text box, type the Subnet Mask address that you located on the network configuration page.
  10. In the Default Gateway text box, type the Default Gateway address that you located on the network configuration page.
  11. Click Apply to save these settings.note.pngNOTE:After the new IP address is set in the EWS, the computer loses the connection with the product, and the EWS page becomes unresponsive. This is expected behavior. Wait 10 seconds, and then continue with the next step.
  12. Close the Web browser.
Step three: Restart communication and complete the installation
  1. Press the press and hold the Cancel button for several seconds. The network configuration page prints.
  2. Make sure that the product is connected to the network and that the IP address matches the IP address that you typed in 'Step two: Set the product IP information in the Embedded Web Server (EWS).'
  3. Connect the phone or Internet cable to the back of the router.
  4. Continue the product installation. If the software has already been installed, insert the software CD into the computer CD drive, and then select Add A Device from the menu that appears on the computer.
If the installation is successful and the error message does not appear again, the issue is resolved, and there is no need to continue troubleshooting.If the installation is not successful and the error message appears on the product control panel, continue with the steps in the Workaround section.Method two: Resolve the error on a product that uses a wired (Ethernet) connectionStep one: Print a network configuration page
  4. When the product is in the ready state, press and hold the Cancel button for several seconds. The network configuration page prints.
  5. On the network configuration page, check the Network Connection Status line. If the status entry reads Ready , continue with 'Step two: Set the product IP information in the Embedded Web Server (EWS).' If the status entry reads anything else, continue with the next step.
  6. Make sure that the network cable, or LAN cable, is connected to the computer and to the product.
  7. When the product is connected to the network, press and hold the Cancel button for several seconds. The network configuration page prints.
    • IP Address
    • Subnet Mask
    • Default Gateway
  6. In the left pane of the Networking screen, select Wired (802.3) , and then select the IPv4 Configuration tab in the right pane.
  1. Press and hold the Cancel button for several seconds. The network configuration page prints.
Or else remove CMOS battery located on formatter, wait 15mts refix then check..
Oct 06, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Message light keeps flashing, but no message- Polycom 550
This is usually a problem with the phone's configuration. Is this phone getting it's configuration from a network server or pbx? If so, find the configuration file for your specific extension and find this location. This example is for a phone whose extension is 2704
msg.mwi.2.subscribe=""
msg.mwi.2.callBackMode="registration" msg.mwi.2.callBack="" msg.mwi.3.subscribe="" msg.mwi.3.callBackMode="registration" msg.mwi.3.callBack="" msg.mwi.4.subscribe="" msg.mwi.4.callBackMode="registration" msg.mwi.4.callBack="" msg.mwi.5.subscribe="" msg.mwi.5.callBackMode="registration" msg.mwi.5.callBack="" msg.mwi.6.subscribe="" msg.mwi.6.callBackMode="registration" msg.mwi.6.callBack=""/>
If you are not using a network-based configuration, the phone's settings can be changed via the phone's internal web server. Open a web browser window and enter the phones' IP address, i.e. http://192.168.1.109. The default user is 'Polycom' and the pass '456'. Go to the links at the top for each line you are using and scroll to the bottom, you will see the voicemail settings there. Use the above info to fill in the correct info, save the settings and the phone will reboot.
Feb 23, 2011 | Polycom IP 550 IP Phone
Wireless does not seem to work any suggestios
Go to HP Wireless Printing Center.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 26, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Why does the facebook could not be open?
This problem can occur if there is a mismatch between the configured IP addresses in the Advanced IP Addressing dialog box and those listed in the Server Properties dialog box for the DNS server. This problem can also occur if the TCP/IP protocol is not bound to the network adapter.
User Action:
Verify that the TCP/IP addresses configured in the Advanced IP Addressing dialog box match those configured in the Server Properties dialog box in DNS Manager: 1. Open Control Panel, and double-click Network. 2. Click the Protocols tab, and click TCP/IP Protocol in the Network Protocols list. 3. Click Properties, and click Advanced. Match the IP addresses to those displayed on the Interfaces tab of the Server Properties dialog box in DNS Manager: 1. In DNS Manager, right-click the DNS server name, then click Properties. 2. Click the Interfaces tab, and compare the IP addresses with those from the Advanced IP Addressing dialog box. 3. Repeat steps 1 and 2 for all DNS servers configured in DNS Manager. If there are no IP addresses configured in the Advanced IP Addressing or on the Interfaces tab of the Server Properties dialog box, enter the IP address of your network adapter. Use the ipconfig -all command at the command prompt to obtain your IP address. Check the binding of the TCP/IP protocol to the network adapter: 1. Open Control Panel, and double-click Network. 2. Click the Bindings tab. 3. Verify that the bindings for all protocols to network adapters are enabled, and that no broken connections exist in the stack.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 25, 2010 | Computers & Internet
Server unreachable
go to menu --> settings --> network configuration --> server menu and scroll down to server address and give the server ip address and save the settings and reboot
Mar 26, 2010 | Nortel i2004 IP Phone
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Open Questions:
Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 19, 2018 | Toshiba Computers & Internet
See all Siemens Gigaset-DE380-IP IP Phone Questions
Siemens Gigaset-DE380-IP IP Phone Logo
362 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
