Question about Acer Aspire 5500 5570-2609 Laptop
How do i control the brightness mine goes in and out (light to semi-dark) all by itself
  • 388 Answers
Likely a loose cable or your screen is starting to go if it's doing it at random. Best bet is to run a screen diagnostics on it using SANDRA lite and then open up the front panel and see if the cables are in tight.
Posted on Sep 06, 2010
Mitsubishi TV 65 inch rear projection. WS 65809 I went thru the convergence ic chip replacement years ago. Love the TV. My problem now is that the brightness goes from full bright to full dim then...
The old Mitsubishi units had a super capacitor in the logic circuit instead of a backup battery. This capacitor became leaky over time, causing the problem you describe among others. Number one symptom is set has audio and dark or black picture when powered up. As the super cap charges to full voltage, picture comes and goes.
Nov 27, 2014 | Televison & Video
The picture is very dark and want to brighten it
If your keyboard doesn't have a brightness control button (mine is F6), open System Preferences and click on the Displays control panel. Move the brightness slider to the right to increase brightness. If you don't want the computer to automatically adjust brightness uncheck the box next to Automatically adjust brightness as ambient light changes.
Dec 26, 2013 | Computers & Internet
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
I have a HP Compaq presario V6000 and the screen is very very dark. I have tried the easy stuff first like the brightness control with and without the 'FN' key and have also installed a new display...
Is it the same runing on your power block without a battery connected?
Is there additional controlls in the form of a button on the monitor itself?
Are you using the original system that came with your model or a pirate Windows or borowed DVD from someone else?
Brightness is the same for the boot screen as in Windows, or in Windows suddenly goes darker?
Have you tried downloading the newest driver from the manufacturer? They usually come with more controls than the same driver from the HP site.
Is there a difference in brightness if you log in as a different user, your profile could be corrupted.
Boot from a Windows or other CD/DVD or bootable USB device, is the brightness working again?
Aug 25, 2011 | Computers & Internet
Dark semi circle shadow and pics too bright
Are you using a lens hood? Is your ISO set too high?
Apr 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
Changing the bulb for a headlight
I guess you refer to the dipped beam headlamp?
If the light is a normal one, not the fancy expensive bright lamp, bluish colour light emitted you should be able to reach it throgh the wheelarch after removing part of the plastic trim.
The cover rotates and can be easily removed.
The there is the usual wire spring loop that hold the lamp in.
The lamp in mine was a standard H1 single filament bulb.
Took about 20 minutes to replace in semi darkness with the aid of a wind-up torch!
Hope this helps.
Paul H.
Apr 30, 2009 | 2004 Mazda 6
Sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
Feb 28, 2008 | Sony VAIO PCG-K35 Notebook
PS2 Picture Problem
Hi MG86,
Most PS2 games are dark and auto brightness controls will casue your LCD tv to brighten up automatically in response the dark video coming from PS2 games. I suggest you get into the menu settings of your TV and find a setting that will shut off the auto picture controls.
Nov 23, 2007 | Sony PlayStation 2 (PS2) Console
Scceen flickers on and off
You'll have to describe the problem in a bit more detail, because it could be a couple different things based on when it goes dark and what "dark" means.
I'm going to guess that the monitor is turning itself off after that second, but you might be describing that it doesn't say it's off, but there is no image (or maybe a really faint image that you can see in the bright light). Try checking it in the bright light after it goes dark. Also, does it seem different if you bang on, shake, or turn it upside down. Don't do this if you haven't already as it will more likely damage it than fix it, but if you have already banged on it, does it change?
I'm working on the same model with a similar problem (not sure it's the same) and will be ripping into it soon and will post the results.
Nov 02, 2007 | Liquid Video A170E101 Monitor
Acer Aspire 5500 5570-2609 Laptop Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
