Question about Kenmore Washing Machines
I have a kenmore elite top load washer, can not find paperwork or model # on machine. It will not spin clothes dry. I believe the belt just needs tightening but I have never done so. what are your thoughts and how do I get to the motor?
    Genius:
  • 1,044 Answers
There is a metal plate giving the Make, Model No and the serial no and other details either at the bottom of rear cover plate OR at the top. Also, the details of the machine are always given on the Sales invoice/receipt. If you have misplaced/lost it you can go back to the retailer from whom you purchased the machine and get these details. If the machine is not spinning the clothes dry then the problem is not with the belt it is the programming in control panel which you can not do it yourself. This requires change of control panel. For that you have to contact the service representative in your area and get the needful done. You can approach the belt by opening the back cover and below the drum is the motor and the belt which can be seen easily.
Posted on Sep 06, 2010
Testimonial: "very helpful, thank you for the quick response."
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washer will not spin sometimes
look under for the belt(s). Belts must be clean and dry, and in good shape, no oil or grease on them. If the machine is leaking on the belt, it will slip. Detergent will make the belt slip.
Apr 01, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Kenmore front load wet clothes
Before going further it is important to determine if the machine is reaching full spin. Make sure the unit is set to MAX extract and watch the inner tub. The tub should be spin really fast (1000 rpm's or better) during the final spin. If not you have lost one of the phases on the motor.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
