Question about Gaggenau 11 in. VG 231 Gas Cooktop
Model VG230-811 - burner stays on only on high setting. Flame gradually goes out at lower settings. What might be wrong?
Why do Jenn-Air cooktop igniters click when the exhaust fan is on med-high and the burners are on low flame setting ? ?
Igniters sense flame temperature, and if the fan cools the temp sensor down, your cooktop thinks the flame has gone out, so it clicks to reignite it.
Sep 02, 2014 | Jenn-Air Cooktops
No flame touching thermocouple
There must be a blockage on the inner flame ring as the gas is not getting to the thermocouple .
Apr 21, 2017 | Gaggenau 11 in. VG 232 Gas Cooktop
When lighting one of the burners, the ingnition knob has to be held down over ten seconds for the flame to stay lit when the knob is released..
Lift the top of the Stove up.
Look for a Small line that goes to the Affected Burner.
At the end of that Line you will see a small Flathead Screw.
Turning That screw Clockwise Adjusts your Pilot Light for that Burner.
Be careful not to Adjust to High, it would just be a Waist of gas.
hope that helped.
May 20, 2009 | Gaggenau 11 in. VG 232 Gas Cooktop
Kitchenaid 30'' low flame output
It's wasn't the perfect solution but I removed all the burner caps and cleaned each one with a tooth brush. Then using a metal trussing pin, I poked through the flame holes to clean them. Noticed better flame output from both.
Mar 06, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Burner goes out when cabinet door is opened!
i haven't worked on one of these models hands on but on most you can pull the burner **** and look inside you should see a tiny ***** in there hold the outer piece with a pair of pliers and take a tiny screwdriver and after turning the burner on turn the ***** to adjust the flame just enough so the suction doesn't blow the flame out on the lowest setting
Mar 08, 2008 | Cooktops
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
Burners only work half way
Remove the burner knobs, inside of each shaft is a straight slot screw adjustment, use a flshlight to see it. Sears has screwdrivers this small.While holding the shaft with a pair of pliers turn the screw in the shaft, it will be hard to turn, this is normal.
Continue doing this until you obtain the desired flame setting.
Oct 11, 2007 | GE 30 in. JGP337 Gas Cooktop
Gaggenau 11 in. VG 231 Gas Cooktop Logo
93 people viewed this question
Top Gaggenau Cooktops Experts
paulcarew
Tall Tiger
Tall Tiger
Dave Lammas
Level 1 Expert
Are you a Gaggenau Cooktop Expert? Answer questions, earn points and help others
